Old 01-27-2022, 09:48 AM   #11
Liked 10,726 Times in 2,233 Posts
Default Re: Where is it legal to add ballast?
And don’t forget to honestly answer the What happens if..........question!
I bought a car that had 127lbs in the box SECURED by two 3/8 bolts on a single thickness of trunk floor pan. On top of that the rear firewall was mostly carpet. I hate to think what would have happened at speed in an accident.
Old 01-27-2022, 11:23 AM   #12
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Talking Re: Where is it legal to add ballast?
Originally Posted by mjacquesjr View Post
General Regulations Section 21, page 19
General Regulations
Requirements) is permitted. Removable weight must be securely
mounted to the frame or frame structure by a minimum of two
1/2-inch-diameter steel bolts per 100 pounds, or one 3/8-inch
steel bolt per 5 pounds; all other weight bars, pucks, etc. must
use minimum 1/2-inch-diameter SAE grade 8 bolts for attachment.
Hose clamps, wire, strapping, tape, tie wraps, etc. for securing
weight or ballast prohibited. Acceptable forms of ballast are 1)
Heavier gauge steel floors (i.e., 16- or 18-gauge, heavier gauge
and/or plate steel prohibited); 2) Frame reinforcing cross members;
or 3) the addition of protective equipment such as roll bars,
flywheel shield, etc. If additional ballast is needed and is permitted
by Class Requirements, it must be permanently attached to frame,
bolted with two 1/2-inch-diameter bolts per 100 pounds, with nuts
welded to bolts. Maximum amount of removable and/or permanent
ballast, unless otherwise stated under Class Requirements, is 500
pounds. Cars running 8.49 and quicker are limited to 250 pounds
maximum, per SFI chassis specification.
Seems counter intuitive that welding a nut to a bolt, which then makes both more brittle in that area, is the rules solution. If this acceptable for weight boxes, they why do collectors need tethers and not just welded bolts to nuts? Why is there not any, or very minimal rules, about how to mount an aftermarket race seat? I weight 275#, so I am 3, 1/2" bolts worth. I might be using logic and thinking too much though...
Andy Friar
Andy Friar is offline   Reply With Quote
Old 01-27-2022, 03:15 PM   #13
Adger Smith
Liked 880 Times in 311 Posts
If your car is a big wheel stander you might move it between the rear suspension and trans cross member.
Adger Smith (Former SS)
Old 01-27-2022, 04:14 PM   #14
Billy Nees
Liked 7,761 Times in 1,741 Posts
I remember a real good article on ballast done by Sheldon Gecker in the National Dragster(?) quite some time ago. It might be worth trying to find.
Billy Nees 1188 STK, SS
Old 01-27-2022, 04:36 PM   #15
west coast
Liked 223 Times in 73 Posts
Best place for ballast is at the end of the track, waiting for you to it pick up.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 01-27-2022, 05:13 PM   #16
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
The requirement that the 1/2" bolts for permanent ballast be welded but the 1/2" bolts for the removable ballast can remain unwelded is probably not specifically for safety. It's probably more about honesty. And I don't think we are talking about welding the bolts so hard that they get cherry red. A little spot weld or a small amount of braze has passed tech all the time.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 01-27-2022, 07:14 PM   #17
my69396
Liked 46 Times in 20 Posts
Are we talking stock as 100 lbs is all that is legal of removable weight.
my69396 is offline   Reply With Quote
Old 01-27-2022, 07:14 PM   #18
West Coast do you race a Camaro with a water leak?
Old 01-27-2022, 07:49 PM   #19
e vassar
Liked 271 Times in 107 Posts
I know this was meant in jest,but be careful folks. Awhile back D4 was checking everyone at fuel check for loose ballast inside the car. A few racers got bounced!
Old 01-27-2022, 08:41 PM   #20
Tom Meyer
Liked 354 Times in 120 Posts
_Or an nice bead of silicon covered with a quick coat of paint. Just joking.
Tom Meyer 5240 SS Stock ???
