#11 |
Liked 10,731 Times in 2,233 Posts
And don’t forget to honestly answer the What happens if..........question!
I bought a car that had 127lbs in the box SECURED by two 3/8 bolts on a single thickness of trunk floor pan. On top of that the rear firewall was mostly carpet. I hate to think what would have happened at speed in an accident. |
#12 | |
Liked 226 Times in 76 Posts
Seems counter intuitive that welding a nut to a bolt, which then makes both more brittle in that area, is the rules solution. If this acceptable for weight boxes, they why do collectors need tethers and not just welded bolts to nuts? Why is there not any, or very minimal rules, about how to mount an aftermarket race seat? I weight 275#, so I am 3, 1/2" bolts worth. I might be using logic and thinking too much though... ![]()
Andy Friar |
#13 |
Liked 880 Times in 311 Posts
If your car is a big wheel stander you might move it between the rear suspension and trans cross member.
Adger Smith (Former SS) |
#14 |
Liked 7,762 Times in 1,741 Posts
I remember a real good article on ballast done by Sheldon Gecker in the National Dragster(?) quite some time ago. It might be worth trying to find.
#15 |
Liked 223 Times in 73 Posts
Best place for ballast is at the end of the track, waiting for you to it pick up.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
#16 | |
Liked 49 Times in 15 Posts
Dean Feiock -- Stock 5002 |
#17 |
Liked 46 Times in 20 Posts
Are we talking stock as 100 lbs is all that is legal of removable weight.
#18 |
West Coast do you race a Camaro with a water leak?
#19 |
Liked 271 Times in 107 Posts
#20 |
Liked 354 Times in 120 Posts
The requirement that the 1/2" bolts for permanent ballast be welded but the 1/2" bolts for the removable ballast can remain unwelded is probably not specifically for safety. It's probably more about honesty. And I don't think we are talking about welding the bolts so hard that they get cherry red. A little spot weld or a small amount of braze has passed tech all the time.
_Or an nice bead of silicon covered with a quick coat of paint. Just joking.
Tom Meyer 5240 SS Stock ??? |
