Old 01-17-2022, 08:55 PM   #1
SS BRP
Default Cast Iron manifolds on Super Stock cars
I saw a 1964 Ford Galaxie FE 390 Super Stocker at my local classic car dealership and noticed it had factory cast-iron exhaust manifolds leading down to about a 2.25/2.5 inch full exhaust system. Were there no long tube headers around in 1964? Was it a Factory class rule back then? Also curious about the small exhaust diameter on a big block engine…
SS BRP is offline   Reply With Quote
Old 01-18-2022, 03:07 AM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Cast Iron manifolds on Super Stock cars
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 01-18-2022, 07:51 AM   #3
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
The only cast header that came on a 390/330 hp was the short style. The long style was exclusive to the 427, including the high riser, which also required a different z bar. There were tube headers available by companies like Belanger. I have a set that has #3 and #7 cross over to the other side, and #4 and #8 wrap around the frame.
427FE is offline   Reply With Quote
Old 01-18-2022, 07:58 AM   #4
427FE
427FE's Avatar
pic
Old 01-18-2022, 09:54 AM   #5
SS BRP
Thats what this 390 had, shorty style cast iron manifolds with a straight 2.25 inch pipe going all the way up through the fire wall to bolt up to it. I thought it was really strange, did they race with that setup or would that system later be swapped out for long tubes? Like a set of Doug Thorley’s or something?
Old 01-18-2022, 01:18 PM   #6
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
A few thoughts come to mind. First, maybe the old headers were too rusty to be re-used if the car was restored. Second, if the car was raced that long ago it could have used the shorty cast headers even though tube headers were available. Or...third, the car could be a clone that replaced the original racecar.
Travis Miller is offline   Reply With Quote
Old 01-18-2022, 03:09 PM   #7
Rory McNeil
Liked 1,104 Times in 302 Posts
Or fourth, it may have never been raced as a Super Stocker at all. I see so many "race cars" at shows, that have never seen a dragstrip. But I have seen plenty of poser cars , belonging to guys that think a few stickers are all it takes to have a "race car". Seen way too many 64 Fairlanes with a bubble hood, and "Thunderbolt" and "427" stickers on the sides, with a small block under the hood. Kinda like the hundreds of 67-69 Camaro "Z/28s" with automatic transmissions, and a 10 bolt sitting on mono leaf springs.
NHRA 6390 STK
M/S 85 Mustang
Old 01-20-2022, 09:15 PM   #8
Adger Smith
Liked 880 Times in 311 Posts
Those factory cast iron header/manifolds are not to shabby. A few years ago when I was doing Tech at Engine Masters Challenge one of the participants made some respectable pulls with a 406. He changed from his tube headers to a set of the shorty 427 Ford cast iron manifolds/headers. His power didn't fall off that much (6500 RPM limit) and the Tq actually went up at a lower RPM. Pretty good design for back in the day...
Adger Smith (Former SS)
Old 01-20-2022, 09:19 PM   #9
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Cast Iron manifolds on Super Stock cars
Seems to me that cast iron header type manifolds were around back then. I remember seeing some 390 Ford Galaxies,around '62-64 thaathad a good looking set of manifolds on them. The regular rectangular exhausts like a 352 or a standard 390 had weren't too much to talk about, but the cast iron headers were pretty interesting. '63-64 400 horse and 425 horse 409's had a good exhaust manifold, so did 421 Pontiacs. There were others as well, but none of the cast headers could compete with a good set of four tube headers.
Old 01-20-2022, 11:41 PM   #10
427FE
427FE's Avatar
Lightbulb Re: Cast Iron manifolds on Super Stock cars
Some those early Pontiac manifolds were aluminum as well
