Old 12-06-2021, 09:44 PM   #11
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: Tech west / 7AL2 problem
Have you check the timing while the problem is happening ?
Timing mark is always rock solid for me . Is the ECU controlling
the timing advance? What ECU are you using for the FI?
Are you using a crank trigger or distributor trigger ?
Willyracer is offline   Reply With Quote
Old 12-06-2021, 10:31 PM   #12
Rob Petrie E395
Liked 216 Times in 77 Posts
Holley yes on crank trigger. No I’ve never checked timing while it’s doing it. It sounds terrible barely running, like a blubbering flooded engine or it’s firing but way way retarded. You know it instantly if it’s doing it. I always shut it off because it sounds so bad. Like I said before click ign switch off. Right back on restart and it’s fine. One time I did click it off and pull plugs to see if it was flooding. It plugs were fine. All I can think is something occasionally happens in the box. But resets clicking it off. I’m not sure it would stay running long enough to hop out and hook up a timing light. I’ve changed everything. I really skipped the box. Because it’s been tested. I had almost resigned that I’d just keep going until whatever it is quits all together. But like I wrote before I read all those tech west posts and saw what was up with msd. And started thinking maybe that’s where the problem is after all.
Old 12-07-2021, 01:05 AM   #13
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
Rob PM Sent
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 12-07-2021, 01:35 AM   #14
Rob Petrie E395
Originally Posted by Joe Schweigert View Post
Rob PM Sent
Sent one back to you
Old 12-07-2021, 02:51 AM   #15
Adger Smith
Liked 880 Times in 311 Posts
What does the battery voltage do when it blubbers?
Plates in the battery shorting or a bad ground?
Adger Smith (Former SS)
Old 12-07-2021, 12:08 PM   #16
Rob Petrie E395
Plates in the battery shorting or a bag ground?
I checked grounds. Actually completely rewired the car at one point. It’s had a optima red top. But now that you say that. I’m not sure the battery has been switched. I know it’ll do it with the alternator on or off. Pretty sure voltage is steady. But I’ll look at that first thing if it still does it after msd box change. I’ve got a digital gauge in the car. So that’ll be easy. It’s never not restarted. But it is very frustrating and frankly embarrassing. Made my primary living for over 30 years as a mechanic and I built this thing. And I haven’t found the problem in years of trying. It’s honestly why I’ve never mentioned it before now.
Old 12-07-2021, 01:45 PM   #17
Adger Smith
Rob,
I had a water pump putting out RFI that caused mine to have a high RPM miss fire. The miss showed up when I had the pump fail and I put on a spare that I was carrying. Turned the pump off during a run and the miss quit. These electrical gremlins can be tough to find and fix. Good luck.
Old 12-07-2021, 02:28 PM   #18
GTX JOHN
Liked 2,506 Times in 701 Posts
My boy uses them and I do not on identical Stockers.
I have never seen a performance gain either way back
and forth from their box.
Search their feedback on here and elsewhere.
John Irving
741 Stock
741 Super Stock
Old 12-07-2021, 07:42 PM   #19
Signman
Liked 269 Times in 99 Posts
The advantage to what TechWest does is faster switching giving more multiple spark at low RPM and at a higher RPM than a stock MSD. If you can add more fuel you will improve.
The basics I was taught were an engine will use as much ignition voltage/amperage as it needs, you really can't have too much ignition but you can not have enough. The truth is we are not making the cylinder pressure to require a 7 series MSD most of us are fine with a 6 series.
There are probably as many racers who have had a good experience with TechWest as bad. Hopefully they will make things right for those at a loss.
Old 01-13-2022, 05:00 PM   #20
Rob Petrie E395
I think I finally found my problem. I bought a tech west box from another racer. We switched it out yesterday. There is definitely something wrong with my box. Even though MSD says it’s fine. On top of just totally acting up at times. When the car was cold it didn’t exactly idle great below 13-1500 rpms. And in the winter of for some reason I needed to start it and the car was cold. You had to feed it some throttle to keep it going. I figured it was mostly my tune up. But have never iced the car at the track. And I usually want it about 130° at the beginning of a run. So it’s never been a problem really. We’ll it was 38° in the shop yesterday. And it’ll fire right up now. We started it and shut it off hot, cold, got it hot and filled it off. Probably started it 30 times yesterday and 15-20 today. It’s fine and you can literally tell it idles better. So we switched it back again today. And you can tell something is going on. Not saying Pats work cured it. But if you have a suspect MSD box. Not sure I’d send it to MSD to be checked. I’m going to send this box to Tech West and let him test it. But after several years. I think I found my electrical problem FINALLY. Now I just gotta get me fixed so I can go racing again.
