Old 12-03-2021, 09:09 PM   #1
Project 392
Liked 26 Times in 15 Posts
Default AMC roller lifters
Hello all. Wondering if someone can identify the manufacturer of these AMC solid roller lifters for me. Searching the WWW has not turned up anything for me. Definitely AMC, set fits the block. Thanks,
Victor in Kingman
ID:	61410   Click image for larger version
ID:	61411   Click image for larger version
Project 392 is offline   Reply With Quote
Old 12-04-2021, 01:56 PM   #2
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: AMC roller lifters
A.H. Adkins in West Virginia will probably know.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 12-04-2021, 04:49 PM   #3
carl hinkson
Liked 18 Times in 10 Posts
Default Re: AMC roller lifters
Victor in Kingman
Are those lifter for and AMC or AMC size. Look really short
carl hinkson is offline   Reply With Quote
Old 12-05-2021, 03:59 AM   #4
Project 392
The mockup in the block is fine. I have heard that they could also be used in a Mopar, probably with different tie bars. I don't think any manufacturer uses that type of tie bar anymore.
Victor in Kingman
Old 12-05-2021, 09:36 AM   #5
pmrphil
Liked 345 Times in 149 Posts
Victor in Kingman
Last one that I knew of was Isky, don't know if they still do use them now or not.
Phil Molski
PMR Performance
S/C 1623
Old 12-05-2021, 12:25 PM   #6
carl hinkson
Victor in Kingman
Mopar has no prevision for push rod oiling
Old 12-05-2021, 12:54 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 858 Times in 234 Posts
They look like Very old Comp lifters.
I have not had a roller cam AMC in many years but the two lifters I used were Comp and Crane .
Lots of choices now that .904 lifters are available with pushrod oiling and in many different oil band locations , but I would only use them if not bushing the lifters.
I used to bush the bores with the oil feed hole located to match the oil band of a small block Chevy lifter with a .842 body and a .750 wheel due to the small base circle on the cam i was using and also used Ford tie bars.
Now that Jesel and T&D have high ratio rockers I would bush the bores to decrease oil loss and go with a conventional base circle,. But still use the SBC bore lifter to maintain an optimum oil gally diameter
Old 12-05-2021, 05:50 PM   #8
jmantle
Liked 169 Times in 80 Posts
I have a couple of sets of older Comp AMC lifters here from my bracket car and they have non separable tie bars. Even though Comp didn't say you had to, I had to bush the lifter bores as the slot for the roller was into the oil gallery at full lift.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 12-05-2021, 06:14 PM   #9
Project 392
Thanks all.
It's probably a moot point on who made them. They are brand new. Just need to mock it up to make sure the body groove doesn't uncover the lifter oil galley passage for a pressure loss at lift.
Tom, I have one block that is sleeved and set up for chebby lifters and
ford tie bars like you did.
Looking to see what else I need to build two motors with the parts I have on hand. One will be a street/strip with ported iron heads and a 4 speed. The other is a Fred Brewer headed 427 AMC, sheet metal intake with Turbo 400.
Thanks again,
Victor in Kingman
