#31 | |
Liked 431 Times in 224 Posts
S/ST 51 S/C 53 |
#32 |
Liked 7,768 Times in 1,741 Posts
Dan should stop sowing the seeds of confusion. Nothing needed to be "fixed".
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 11-12-2021 at 01:42 PM. |
#33 | |
Liked 867 Times in 165 Posts
1189 F/SA Defunzalo Racing Enterprises Last edited by Doug Hoven; 11-12-2021 at 03:44 PM. |
#34 |
When the LT-1 engines and other EFI engine makes were introduced into drag racing, Jim Skelly was the guy that approved the use of aftermarket EFI ECU's and also approved the use of the crank trigger systems on engines that have a crankshaft position sensor in lieu of a single distributor that handles the ignition duties. The current language that everyone has used throughout the years was written by Jim and has not changed.
This same issue has taken place with other engine makes of ignition systems that have been previously approved by NHRA and later on deemed to be illegal only to be rescinded when NHRA found the original acceptance. Below is a depiction of the OEM crankshaft sensor position on the LT-1 engine and Jim did not see an issue allowing the use of a crank trigger system in lieu of the OEM sensor because they both perform the same function. ![]() Last edited by SSDiv6; 11-12-2021 at 04:20 PM. |
#35 | |
Liked 38 Times in 17 Posts
K Danner STK 468 |
#36 | |
Liked 534 Times in 143 Posts
The rule book is a bit out dated, but how can you not allow a car in the guide to run the same equipment as it came from the factory? Would tech bounce a purely stock LT1 because it has a crank sensor? |
#37 | |
It was the premise used by Jim Skelly to allow the use of crank trigger systems on the LT-1 and other EFI engines, based that the cam and crankshaft sensor are separate functions from the cap and rotor that all they do is distribute the electrical current to each spark. The same situation I went through with Pat on the Cobra Jet 429 Ninja when he told me I could not use Coil-On-Plug (COP) because it was based on a Windsor engine. Well, Ford Racing had gotten approval to use either a distributor or COP ignition and it had been approved by NHRA and was told by the Indy Office it was legal to run COP. By the way...Happy Birthday Kyle (Mr. Sheep Husbandry Expert...) ![]() |
#38 |
Hahahaha! Thanks bud.
#39 | |
1189 F/SA Defunzalo Racing Enterprises |
#40 |
Liked 880 Times in 311 Posts
When did Pat become the National Tech director?
Sometimes it takes a long hard look at the wording and punctuation of the rule & understanding the function of the factory systems I would to go to the top to get the correct/final answer
Adger Smith (Former SS) Last edited by Adger Smith; 11-13-2021 at 12:41 PM. |
