Old 10-28-2021, 02:56 PM   #1
tolaas
Default Moroso oil pan
I`m building a 67 stock camaro small block and i gone use 20180 moroso oil pan, anyone who knows if it fits into the fram or do i have to do some modifications?
tolaas is offline   Reply With Quote
Old 10-28-2021, 06:07 PM   #2
SSDiv6
Default Re: Moroso oil pan
There are several quality issue complaints on this specific Moroso pan in the Summit Racing website.
I prefer and use the approved Milodon oil pans and they fit like a glove and it clears and fits the Camaro frame..
Old 10-28-2021, 08:53 PM   #3
Lyn Smith
Liked 1,002 Times in 203 Posts
Milodons have some fit, and leak issues also. My 30700 leaks in the corners from under the corner reinforcements, and also the curve of the pan rail is smaller than the standard 5/16 bolt heads.
Old 10-29-2021, 06:00 AM   #4
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Moroso oil pan
Good morning,
I use that pan on my engine and the Fel Pro one piece gasket.
I do seal it to the block, timing chain cover and rear main cap with coating of "grey" silicone. I also check the bolt hole locations as some don't line up as well as others.
No leaks at this time.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 10-29-2021, 08:26 AM   #5
Rsmith38
Liked 28 Times in 15 Posts
Call Scott Hall at Moroso - he can tell you what fits
Rsmith38 is offline   Reply With Quote
