#11 |
Liked 880 Times in 311 Posts
Had a customer with a similar problem. took 4 runs to slow down and stabilize. turned out to be a worn converter sprag.
Adger Smith (Former SS) |
#12 |
Liked 230 Times in 106 Posts
Don't think that the case here. Change tranny out to spare trans with same converter and boom within 1-2 (60 ft) every run. Spare is just not as fast because it does not have alum stuff in it. Spare is an point A to point B trans.
#13 |
Liked 189 Times in 48 Posts
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
#14 |
Hmmmm, good question. Have not put a gage on "spare" trans because of no problems. All books and literature shows 145-170 is good number.
#15 |
Liked 71 Times in 38 Posts
Is your pressure gauge mounted in the car or is it a diagnostic type for stationary pressure diagnosis?
#16 |
Liked 89 Times in 28 Posts
Are the high gear clutched showing signs of slippage?
#17 |
Trans guy says no although I'm glad you asked that. Well seasoned Super Stock racer in my area asked the same question. He said "I'll bet it high gear clutches or clearance issue."
#18 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
#19 |
Liked 5,077 Times in 1,935 Posts
It should push through if outlet plugged..Doubt it would take any hp but worth looking at I suppose.
