Liked 166 Times in 46 Posts
Can the oil pan be successfully removed and replaced with the engine in the car? 455.
Liked 62 Times in 23 Posts
Jim, worked at Olds dealer 1971-1978, found it easier to remove engine for oil pan removal. Crank throws and frame K-member make it very tight in vehicle.
Liked 109 Times in 44 Posts
^^^^^ my experience as well-easier to pull it out
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
Pan is too close to the crossmember. You either have to lift the engine or remove it. There is also the issue with the use of incorrect engine mounts. The big block engine mounts are different than the small block. I have seen a few guys that put small block engine mounts with a big block and it puts the engine even closer to the crossmember.
Liked 239 Times in 114 Posts
Didn't NHRA make a rule that allowed you to modify or fabricate a removable cross member so you could remove your oil pan ? That may be hard to do, on a A-Body GM car but once it is done, it would be easy to remove the oil pan .
Liked 544 Times in 213 Posts
Very similar to a Pontiac
A device was made that allowed you to push the engine up enough from the bottom to get the pan off. It had chains that wrapped around lower frame and used a big bolt device to push the engine up under the balancer/front cover I don't recall the exact details but it did work because I used it more than once in my days as a Pontiac dealership mechanic....Mid to late1970's....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 08-05-2021 at 03:13 PM. |
#7 | |
Liked 129 Times in 35 Posts
No you can't
