Old 07-19-2021, 05:52 PM   #1
junior barns
Liked 20 Times in 14 Posts
Default gear change
Is there a formula that tells the rpm drop at the finish line between different rear gears ? 5.11 to 4.88 to 4.56 etc.
junior barns is offline   Reply With Quote
Old 07-19-2021, 05:55 PM   #2
JeremyDuncan
Liked 355 Times in 80 Posts
Default Re: gear change
http://www.wallaceracing.com/calc-gear-tire-rpm-mph.php
JeremyDuncan is offline   Reply With Quote
Old 07-19-2021, 06:25 PM   #3
L.Fite
Liked 498 Times in 244 Posts
Originally Posted by JeremyDuncan View Post
I did one similar to that in excel...
not as neat as that one but usable.
L.Fite is offline   Reply With Quote
Old 07-19-2021, 08:14 PM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The only iffy part of the calculation is what you use for converter slip . The higher you rev the engine the less slip you get with the torque converter .
Old 07-20-2021, 06:40 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
old fashion way
4.88 divided by 5.13 =.9513
4.87% difference
4.56 divided by 5.13 = .8889
11.11% difference
Original RPM + or - the % difference
The real life number change may vary due to converter slip and/or tire growth.
Adger Smith (Former SS)
Old 07-20-2021, 07:27 AM   #6
Ray Gottry
Ray Gottry's Avatar
Liked 68 Times in 24 Posts
RPM X C
_______ = MPH
G X 1056
MPH X G X 1056
______________ = RPM
C
MPH X G X 1056
_____________ = C
RPM
RPM X C
____________ = G
MPH X 1056
RPM = REVS PER MINUTE
C = TIRE CIRCUMFRUNCE (UNLOADED)
G = GEAR RATIO
MPH = MILES PER HOUR
You can move the numbers around in the formulas to tell differences of changes. Has worked great for me.
Not real scientific but fun.
Ray Gottry is offline   Reply With Quote
Old 07-20-2021, 11:34 AM   #7
Bowtieguy1967
MPH X gear ratio X 336 / tire height (this only works assuming the trans final drive ratio is 1-1)
Examples:
120 MPH X 4.56 X 336 ÷ 28" = 6556 RPM
120 MPH X 4.88 X 336 ÷ 28" = 7027 RPM
120 MPH X 5.13 X 336 ÷ 28" = 7387 RPM
Obviously converter slip is not factored into the equation.
Bowtieguy1967 is offline   Reply With Quote
Old 07-20-2021, 03:37 PM   #8
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
http://atiracing.com/tech/racing_calculators.html
This one @ ATI figures in converter slip.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 07-24-2021, 10:30 PM   #9
junior barns
Thanks all! When making a gear change the mph will change. In general going from a 5.13 going thru the traps at 7300 rpm and changing to a 4.88 what rpm drop can I expect?
Old 07-25-2021, 12:01 AM   #10
Adger Smith
7300 - 4.87% (355.5 RPM) = 6944.9
Providing the converter slip % stays the same.. (It usually doesn't)
