Liked 708 Times in 285 Posts
Want to make valve covers look nice and new looking again. Not wanting polished but mild corrosion, and dull removed. Some kind of blasting, chemical? Thanks. Sorry tried posting picture but it is to large from my phone
Liked 240 Times in 112 Posts
Get some new Glass Bead from MSC or other similar supplier.(But clean all the oil out of them 1st or the glass will pack into wherever its wet.) After a few uses the glass will break down and get real powdery which will change the appearance of what you are blasting.
Dave Noll, EF/S ,?/SA 6526 |
Liked 335 Times in 182 Posts
NAPA aluminum brightener----nasty stuff so follow directions carefully---wear gloves and eye protection---- DO NOT GET IT ON YOUR SKIN OR BREATH THE FUMES ---it will burn you has acid in it---FED 387
Liked 30 Times in 17 Posts
See if there is anyone around that does soda blasting. It will make them look very nice with no chance of engine damage like you have with glass beads.
Bill Koustenis |
#5 | |
You have to be careful. It turns some material dark, rather that bright.
Liked 49 Times in 22 Posts
Wet blasting is amazing what it can do to the finish
Steven Barnes Stock 704 N/SA Last edited by 65signet; 06-08-2021 at 05:40 PM. |
