Liked 2 Times in 2 Posts
need to find out what valve spring seat pressure should be.
checking mine with moroso guage was 220 was thinking they should be 180. .357 / 390 lift. any help anybody. thanks |
Liked 169 Times in 53 Posts
Leon, unless you're running coated lifters and a billet camshaft I wouldn't go over 180 on seat. I've never been able to run 200 on seat without wiping out lobes, and Ive tried all the usual lifter combinations ( hole in bottom of lifters different oils and lubes)etc etc. The tool steel lifters with a nitrided cam is what I use at 180 / 360.hope this helps.
Bill Bogues 4696 STK |
Liked 397 Times in 153 Posts
I would strongly recommend removing a spring, verifying the installed height, and then getting it checked with a Rimac (or similar) spring tester. The Moroso unit will vary depending on rockers, among other things. It's best used to check to see that all springs are equal.
Phil Molski PMR Performance S/C 1623 |
Liked 39 Times in 9 Posts
190 on the seat with Smith lifters. (I use the same 305 engine combo). No problems, just check them lifter pucks regularly.
Reggie Winkles 2650/Stock |
