Old 12-29-2020, 12:43 PM   #1
6130
Liked 117 Times in 50 Posts
Default Best unleaded from the approved fuel list for turbo Stocker?
Considering a 2015 Ecoboost Mustang for I/J/K Auto.
I see Sunoco 260GTX and VP C10 on the list. Anything else I should be considering?
Old 12-29-2020, 12:57 PM   #2
HawkBrosMav
Liked 302 Times in 73 Posts
Default Re: Best unleaded from the approved fuel list for turbo Stoc
Neither are probably worth the effort/price to find consistently for any performance gains you think you might see.. We tried them both with no noticeable difference over just running the easy to find and "cheaper" Sunoco 110 purple. If you're looking to squeeze every last HP out of it, this might be worth the effort, but based on your other post it seems like this car isn't going to be a record holder or anything like that.
I'm sure others will have another opinion as fuel is something that many people differ on, but this is just with my experience for what it's worth.
Brad
Old 12-29-2020, 02:21 PM   #3
6130
But this car has an O2 sensor or two, that will be used by the stock engine computer for closed-loop operation, and I don't want to be fouling them and replacing them...
Old 12-29-2020, 02:25 PM   #4
HawkBrosMav
If you can by higher quality ones that still interact correctly with the OEM computer that wont be as big an issue as you think it is. We're running and late 80's 302 EFI car and have had zero issues with both the OEM computer system and the new Holley system we put on with running leaded fuel and killing O2 sensors.
Maybe we've just been lucky.. I'll have to look into the O2's we ran with the stock system, but we are running the NTK O2's with the Holley.
Brad
Old 12-29-2020, 02:30 PM   #5
6130
My question was kind of turbo-specific, but thanks for the input, Brad.
Frankly, it should be able to run under on pump 93, with or without a little octane booster for insurance, but pump 93 isn't on the approved list.
Does NHRA conduct fuel checks only at national events, divisionals, or what?
Old 12-29-2020, 02:45 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,966 Times in 595 Posts
They check fuel at divisional, national and national open events in stock and super stock so you will have to run an approved fuel. Pump gas is not legal to run in NHRA competition.
With the new regime taking over in January leaded fuel will be going away soon so hopefully the fuel suppliers are working on unleaded fuel for our type of engines.
Mike Pearson 2485 SS
Old 12-29-2020, 03:28 PM   #7
6130
I hope so.
110 R+M/2 unleaded available and on the approved list, would be pretty cool.
Old 12-29-2020, 09:10 PM   #8
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
VP C-16 is what I run in my SS 84 2.3 turbo Mustang. Not cheap but it works and has never had any issues passing fuel check. I buy a barrel, and transport what I need for each race. I believe that is what the other guys running this combo in stock are also using. We also own a 2016 Ecoboost Mustang, in sport mode it will product over 32-34 lbs of boost. Don't shoot yourself in the foot by not running the right fuel for a turbo combo. As for O2 sensors, I replace mine every season as preventative maintenance. I do not see any change in performance after changing out the sensor.
Stick or auto? If you delete emissions stuff and get the weight down to minimum, that combo will run well under the index. What are you planning on doing for engine management?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-29-2020, 10:04 PM   #9
6130
We're thinking about a VERY basic combo. Stock engine, stock computer, stock converter, and stock rear end gears. Baer SS4 front brakes, 15" Bogarts, mandrel-bent 3" open downpipe, rear O2 spacer, an aftermarket tune, the required safety equipment, and a fuel tap per the rules for fuel testing. If it won't run under, then maybe a converter for the stock 6R80 automatic transmission.
Frankly, I'm thinking of DOT drag tires, license plates, and liability insurance, to avoid the cost of a truck and trailer. It should get at least 30 mpg on the highway. For any race that is any significant distance away, we can rent a U-Haul truck and open car trailer.
Old 12-29-2020, 10:35 PM   #10
Dave Gantz
Liked 251 Times in 125 Posts
It doesn't matter if it gets 300 mpg. It REALLY sucks when (not if) your car breaks, at the track or wherever.
I broke an axle on the starting line. The starter said, "Well, it hooked". Yep, and all of the money flew out of my wallet, because of that hook.
