Liked 22 Times in 16 Posts
Has Any Body Had Trouble Getting A Good Pattern On A Set Of US Gears
Liked 510 Times in 117 Posts
Never had a problem. What diff and ratio?
68 Chevy11 327 F/S |
12bolt 513
What back lash and pinion depth shim thickness?
pinon depth 2.850 backlash .008
What thickness of shim did you use? Reason I ask.
Liked 974 Times in 310 Posts
Did you try using a different pinion shim. Don't be concerned about pinion depth numbers. It's all about pattern and backlash.
Liked 920 Times in 259 Posts
