Old 12-16-2020, 11:05 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Question ATF any real world experiences with Loosing up a convertor?
Test Pig:
The mighty Gremllin, currently running Amalie Type F, which per their spec sheet says is 10-20 weight.
Per the chasis dyno wants 500 looser on the RPM, which is obviously a ton, and not going to happen with just fluid, but with a low HP beast like the Gremlin, we might see more of an effect of the fluid than say your standard 635 HP 396 stocker.......
Reflashing this convertor, too risky. Have a known good enough thing here.
I know just about all the info on the site is about using thicker fluid to lower stall, I'm looking to increase stall as much as possible.
I believe specific gravity is likely the ultimate factor in stall,
So for my type F, using the formula, 141.5/API of 31.5 plus 131.5=.8498
a thinner fluid like their Dexron VI syntethetic with a API of 35 would be a .8681 SG
This is 1.0215% thinner than the type F.
The ATI 0w-8 weight might be a option, I know there are other synthetic fluids out there with real thin weights.
Eric
Eric Merryfield 1883 STK
Old 12-16-2020, 12:10 PM   #2
SSDiv6
Liked 1,568 Times in 579 Posts
Default Re: ATF any real world experiences with Loosing up a convert
Originally Posted by Eric Merryfield View Post
Test Pig:
Eric
Try the ATI fluid or Dexron III which is about 10W viscosity.
Old 12-16-2020, 01:54 PM   #3
Bobby Fazio
Bobby Fazio's Avatar
I have been researching this along with engine oil. I have been focused on viscosity index and kinematic visosity in cSt at 104 degrees F and 212 degrees F. Most manufacturers have data sheets. I haven't been paying much attention to the spec gravity but I will now. ATI Super F 20wt is lighter than Amalie Type F by a few numbers. Red Line makes a lightweight racing ATF that is much lighter than both of them. ATI makes 8wt but can't find numbers on it.
'65 Mustang SS/L & L/SA
Old 12-16-2020, 02:10 PM   #4
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
Buy another convertor that is looser
Old 12-16-2020, 03:43 PM   #5
GTX JOHN
Liked 2,462 Times in 694 Posts
We routinely adjust Convertor stalls without problems
John Irving
741 Stock
741 Super Stock
Old 12-16-2020, 04:02 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
I almost hate to admit how screwed up I am......
When we went chasing performance in converters, I would order an exact duplicate of what was in the car and then A-B, B-A test and then compare them at a test session. If they performed exactly the same then I would send the oldest converter back to be “adjusted”
If the “adjusted “ converter didn’t pick the car up then it came out and we tried something different
That way you never lost what you had and that worked with Q-Jets too...
No computers just 1320’ and a time slip...
Marv Ripes was a way ahead of the curve when he said load up your car and come down to OCIR for a test session with 60’ clocks...
He said bring work clothes and he sat at a card table with the first 60’ clocks that I had ever seen...
We worked our butts off and ran 5 or 6 different converters through the race car that day and I would like to add it was a productive day
Bob Mulry 7516 STK
A & M Motorsports
Old 12-16-2020, 06:19 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
I've used the Redline liteweight ATF. It helped ..... A little. But if a little is all you need, its perfect.
Dave Noll, EF/S ,?/SA 6526
Old 12-16-2020, 06:28 PM   #8
Billy Nees
Liked 7,682 Times in 1,730 Posts
Hi Bob! I hope that all is well.
You made me remember something that the late/great Jim Beattie said to me more that once, "What the f**k is wrong with you Nees? Is there somebody standing at the 60' clocks handing out $100 bills?
Billy Nees 1188 STK, SS
Old 12-16-2020, 10:47 PM   #9
Jeff Stout
Liked 704 Times in 281 Posts
I went the other way to test. Used Hydraulic fluid in low hp sticker. It tightened almost 300 rpm.
I'm getting ready to change out for Redline lightweight and will test in about 3 weeks. Can post results after.
Old 12-17-2020, 09:00 AM   #10
Glenn Briglio
That's exactly how it's done!!!!!!!!
