Old 12-10-2020, 05:57 PM   #61
Bobby Fazio
Bobby Fazio's Avatar
Default Re: What Race Oil do you trust?
Originally Posted by GTX JOHN View Post
I still run Royal Purple 5/20 Racing oil (Old 11) that I
have run literally forever. I am always pleased with
how the engine looks when rebuild time!
For Heads Up = If needed the light Dangerous Stuff
and cross our fingers.
John is this the Royal Purple XPR? I like it but it's roughly $100 for 6 qts!
'65 Mustang SS/L & L/SA
Old 12-10-2020, 11:31 PM   #62
GTX JOHN
Liked 2,471 Times in 696 Posts
Yep............Sorry!
Somewhat cheaper by the Pail.
If that is too pricey = I use Mobil One on my 10 Sec. or slower
Bracket Stuff.
John Irving
741 Stock
741 Super Stock
Old 12-11-2020, 03:56 PM   #63
kfickler
Liked 10 Times in 2 Posts
Hey all,
I'm now with Driven Racing Oil, and would like to help answer any questions you may have regarding our product. You can email me at kfickler@drivenracingoil.com with your questions or your contact info and I will call. Whichever works best for you.
Kyle Fickler
kfickler is offline   Reply With Quote
Old 12-13-2020, 10:26 PM   #64
e vassar
Liked 271 Times in 107 Posts
Have mostly used Mobil 1 and Lucas 10-30 in LT1 and LS cars We tried RP in the LT1 but would not keep the lifters pumped up. We have since went with solids (thanks nhra) 2 questions...do I need a additive with Mobil 1 or Lucas? since both cars have roller cams?...somebody mentioned Mobil 1 5-20 high mileage. Is this OK for all the time oil?
What about a safe heads up go fast oil?
Old 12-14-2020, 01:27 AM   #65
GTX JOHN
I do not think there is a "Safe" Superlight heads up Oil!
I am always worried with the Superlight stuff and can not wait
to get it to the finish and shut the engine down!
John Irving
741 Stock
741 Super Stock
Old 12-14-2020, 11:18 AM   #66
curtis reed
Liked 125 Times in 59 Posts
Originally Posted by Bobby Fazio View Post
Just Trans temp but plan on monitoring both atf and oil temp next year.
Good call. It's surprising how hard it is to keep enough heat in the oil.
curtis reed is offline   Reply With Quote
Old 12-14-2020, 11:41 AM   #67
427FE
427FE's Avatar
Liked 347 Times in 79 Posts
How much heat do you want in the oil?
427FE is offline   Reply With Quote
Old 12-14-2020, 11:42 AM   #68
Bobby Fazio
Does this differ with steel vs aluminum pans?
Old 12-14-2020, 04:58 PM   #69
SSDiv6
Liked 1,577 Times in 581 Posts
After the engine has been broken in with a good break in oil, no need to put any additional additives in the oil, especially with a good brand racing synthetic oil.
There are many choices for a heads-up oil, but also consider the clearances you are running. Putting a thinner oil for a heads up run can also require overhauling the engine afterwards. Engine oils have a low surface tension and it operational temperature changes it. It is a risk you take.
Hydraulic lifters require a minimum of oil Centistokes to operate properly. The lower the oil viscosity, the lower the Centistokes. Centistokes is a measurement of the kinematic viscosity on engine oils, that defines the fluid friction and of the oil's film strength to support a load.
A 30w engine oil at 212 degrees F will have a Centistoke reading of 9.3 thru 12.5; however, 5w oil at the same temperature will have a 3 or less Centistokes.
SSDiv6 is online now   Reply With Quote
Old 12-14-2020, 05:06 PM   #70
SSDiv6
You want around 220 degrees F minimum to get rid of the water vapors and burn any deposits to prevent sludge. Dinosaur oil, 220 degrees F to 250 degrees F. Synthetic oil 230 degrees F to 280 degrees F.
