Old 12-12-2020, 09:38 AM   #11
Liked 10,725 Times in 2,233 Posts
Default Re: Listen to a story 'bout man named Phish
Did the bearing caps have any shim stock between them?
The stuff in the pan could be cylinder block material where the rings plateaued the cylinder walls, just a guess.
Old 12-12-2020, 11:49 AM   #12
Spyphish
Liked 679 Times in 180 Posts
All rod and main bearings had a 100thou spacer and one rod had one little brass shim left. She is wore out. Babbit still there so may mic and polish crank, repour rods etc and buy a shim kit from The Filling Station, clean it up, hone, ring. Chiity Chitty Bang Bang
I learned the cranks bend easy so they suggest spin it in a lathe and check runout. If bent, pry it back straight and roll on. Uncle Jed
ID:	56469   Click image for larger version
ID:	56470   Click image for larger version
Old 12-12-2020, 12:56 PM   #13
Kirk Morgan
Liked 80 Times in 44 Posts
A place called Egge machine use to have parts for those engines. I my memory serves me correctly they had connecting rods that were converted for inserts. I took a restoration class in the 70s and toured there facility. .
Kirk Morgan is offline   Reply With Quote
Old 12-20-2020, 07:31 AM   #14
Spyphish
I have four wooden spoke wheels off of a 1925 series 80 Pierce Arrow if you can use them.
May need them as some of these are weak. Tapered shaft with .380 keyway. I will get shaft outer inner measure with a mic. Next time your by them send a pick to stephenontheriver@yahoo.com
Thanks Phish
Old 03-02-2021, 12:03 PM   #15
Spyphish
Pile of clean parts and turned crank.
ID:	56846   Click image for larger version
ID:	56847   Click image for larger version
ID:	56849   Click image for larger version
Old 03-22-2021, 01:23 PM   #16
Spyphish
Bed and bench done. Plans are to use as pit car at USNATS Lord willing.
ID:	57069   Click image for larger version
ID:	57070   Click image for larger version
ID:	57072   Click image for larger version
ID:	57073   Click image for larger version
