#61 |
Liked 4,387 Times in 504 Posts
John is this the Royal Purple XPR? I like it but it's roughly $100 for 6 qts!
#62 |
Liked 2,493 Times in 700 Posts
Yep............Sorry!
Somewhat cheaper by the Pail. If that is too pricey = I use Mobil One on my 10 Sec. or slower Bracket Stuff.
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 12-10-2020 at 11:36 PM. |
#63 |
Liked 10 Times in 2 Posts
Hey all,
I'm now with Driven Racing Oil, and would like to help answer any questions you may have regarding our product. You can email me at kfickler@drivenracingoil.com with your questions or your contact info and I will call. Whichever works best for you. Kyle Fickler |
#64 |
Liked 272 Times in 108 Posts
Have mostly used Mobil 1 and Lucas 10-30 in LT1 and LS cars We tried RP in the LT1 but would not keep the lifters pumped up. We have since went with solids (thanks nhra) 2 questions...do I need a additive with Mobil 1 or Lucas? since both cars have roller cams?...somebody mentioned Mobil 1 5-20 high mileage. Is this OK for all the time oil?
What about a safe heads up go fast oil? |
#65 |
I do not think there is a "Safe" Superlight heads up Oil!
I am always worried with the Superlight stuff and can not wait to get it to the finish and shut the engine down!
#66 |
Liked 125 Times in 59 Posts
#67 |
Liked 348 Times in 79 Posts
#68 |
Does this differ with steel vs aluminum pans?
#69 | |
There are many choices for a heads-up oil, but also consider the clearances you are running. Putting a thinner oil for a heads up run can also require overhauling the engine afterwards. Engine oils have a low surface tension and it operational temperature changes it. It is a risk you take. Hydraulic lifters require a minimum of oil Centistokes to operate properly. The lower the oil viscosity, the lower the Centistokes. Centistokes is a measurement of the kinematic viscosity on engine oils, that defines the fluid friction and of the oil's film strength to support a load. A 30w engine oil at 212 degrees F will have a Centistoke reading of 9.3 thru 12.5; however, 5w oil at the same temperature will have a 3 or less Centistokes. |
#70 |
