Old 12-05-2020, 08:44 PM   #11
monte8616
Liked 14 Times in 6 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Originally Posted by Jeff Stout View Post
Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.
I don’t have an O2 sensor yet either... we did the new plugs and wires too! Brand new MSD too lol - what’s interesting is that we originally thought that it was the MSD box because when we changed the box and made a pass, it went back to what it should’ve been running - then, after that, it went back to being slow again... ugh
monte8616 is offline   Reply With Quote
Old 12-05-2020, 08:52 PM   #12
monte8616
Check fuel system, , the 30 second jug test is a good start, replace the battery/batteries....Have you done any welding close to the car ? .....Some racers have reported that their car became MAGNETIZED and they lost plenty of ET and MPH ......3 ideas to PONDER ......
What else do you know about the magnetized thing? Very interesting...
Old 12-05-2020, 09:00 PM   #13
Jeff Stout
Liked 706 Times in 283 Posts
I know a local racer that determined the spun bearings came from arcing on crank to bearing clearance and made pit mark's on journal. He had connected ground to block and welded on frame.
Old 12-05-2020, 09:08 PM   #14
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
MSD's pull ,and need, about 8 amps at WOT . They also get a lot of vibration in our cars.. Put a new high current kill switch in it. Their relatively cheap.
Jeff Niceswanger 3740 SS
Old 12-05-2020, 09:12 PM   #15
david edwards
Liked 104 Times in 7 Posts
Ck your grounds.
david edwards is offline   Reply With Quote
Old 12-05-2020, 09:22 PM   #16
James Perrone
Liked 1,856 Times in 433 Posts
Joey this may sound strange
Years ago Micheal Iacono built the yellow SS camaro car was brand new front to back .
Then it developed a gremlin changed everything msd fuel pump retire
Lee Zane was driving the car. Finally made few runs shutting accessories
Bad electric water pump.
Wouldn’t do it unless under a load Worth a look
james perrone 1290 STK
Old 12-05-2020, 09:30 PM   #17
monte8616
Funny u say that - the fuse blows on the water pump intermittently...
Old 12-05-2020, 09:35 PM   #18
monte8616
Originally Posted by david edwards View Post
Ck your grounds.
Did that too...
Old 12-05-2020, 10:19 PM   #19
Bill Marshall
Liked 53 Times in 24 Posts
[QUOTE=Jeff Stout;629310]Not to bash, but it was a Barry Grant pump. It was aerating the fuel. So the gauge was actually air/ liquid pressure. No O2 sensor at the time. Also at the time I was not to smart and threw about 1500.00 and 7al, wires, new tach, plugs. Checked valve springs twice. Cam timing, compression test. Three different outings at track. It was a real learning experience.[/QUOTE
Jeff This car use to be fuel injected and it still has the high pressure pump in it with regulator to knock down the pressure. regulator is set at 7.5 lbs also we dyno'd the engine and it still has the same power from when it was built
Bill Marshall is offline   Reply With Quote
Old 12-05-2020, 10:37 PM   #20
rognelson777
Liked 135 Times in 74 Posts
grounds. disconnect, add serated washers and no lock nuts. nylon in locknut can melt from cranking engine when wire gets hot.
fuel lines. any rubber can actually close down and limit flow when hot
rognelson777 is offline   Reply With Quote
