Old 08-25-2020, 02:03 PM   #21
James L Miller
Liked 25 Times in 16 Posts
Default Re: Advice of Dana 60 Gears
Originally Posted by ss125h View Post
John, I run same car, but a lot less torque (340) with 8.75 ,point is we always have the gears heat treated. Have had very few problems, even running close to 3700 lbs. We do run 6-12 thou. bk-lash, with auto trans. good luck. Glen H 1257
What hardness do you have the gears heat treated? For 8620 and 9310 steels the tempering temperatures are in the 300F to 450F range.
https://www.emjmetals.com/pdf_indexe...loy_Steels.pdf
https://www.emjmetals.com/pdf_indexe...denability.pdf
Mopar 2 Ya!
Old 08-25-2020, 02:56 PM   #22
Ralph A Powell
Liked 227 Times in 138 Posts
Do you guys use the a spreader to get the ring gear out and have preload?
Old 08-25-2020, 05:07 PM   #23
Steve Stasko
Liked 292 Times in 147 Posts
Herb McCandless told me to avoid the spreader unless absolutely necessary. If you're not careful with it, it will bend the housing. A box end wrench on the ring gear bolt, and carefully turning the yoke with push the carrier right out of the housing with little to no effort.
Old 08-26-2020, 08:06 AM   #24
Mike Pearson
Mike Pearson's Avatar
Liked 2,013 Times in 604 Posts
I don't use the spreader. I have just enough preload where it takes a couple of taps with a plastic mallet to get the spool into the housing. I dont run much preload on the pinion either. Doing it this way there is little to no drag. I have been getting great gear life well over 1000 runs. Running either 6.17 or 5.86 ratios depending on the engine combo.
Mike Pearson 2485 SS
Old 08-30-2020, 06:51 PM   #25
GTX JOHN
Thanks to everyone for their help =
We are back together and ready for Vegas Natl's!
John Irving
741 Stock
741 Super Stock
