Liked 115 Times in 35 Posts
Do holley carbs with side hung floats need jet extensions in the rear? If so is a notched float needed as with center hung floats. This would be on a single carb installation.
Liked 226 Times in 137 Posts
If the carb I mounted primary bowl in front and secondary rear it won’t hurt. At one time Holley made jet ext that fit inside the jet they were about 1 inch long. They were made originally for the GT-40s at LeMans when Ford ran the 427 with a single 4V. Those were with what they called the LeMans float bowls. If you check at one time Holley made the nitro black floats for the side hung bowls I think the oe floats were brass. You can not notch those floats.
Liked 348 Times in 152 Posts
If it leaves hard enough to uncover the jets, then yes, it's needed. And, yes, Quick Fuel sells a notched, thinned, float just like that. I always keep one in stock.
Phil Molski PMR Performance S/C 1623 |
