Liked 496 Times in 243 Posts
What back spacing on 8 inch rim will fit under 69 Camaro with 29x9 tire, stock width 12 bolt (with little or no "persuasion")?
With the price of wheels now days, don't really want to guess. |
Liked 200 Times in 62 Posts
Just about every 12 bolt I've worked on had a slight offset with the spring pad location which made the use of a spacer on one side when using the 9inch tire width. I don't think it was done on purpose but maybe jig was worn out, keep in mind they were pumping out ' 69 Camaros like hambergers. I corrected that on mine because I didn't want to use a spacer. I run 15X10 wheels with 5" backspacing. The inner sidewall rubs just enough to rub the white letters off. I have a stick car and the 10" wheel gives a better footprint I believe, with not too much air in 'em. Hope this helps! P.S If I remember right it was Joe Demarzo who put me wise on the spacer, when he was running his '69 Camaro. He keeps very good notes on stuff so he may remember where the spacer went. PPS, Joe was nice enough to loan me wheels to try. Might not be a bad idea to find someone to do the same.
Liked 22 Times in 16 Posts
10 inch wheels 5 inch backspace mine is a stick car also
Liked 779 Times in 193 Posts
4 1/2" backspacing on an 8" wheel.
Liked 454 Times in 147 Posts
I have 2 New Bogart Flylights 15 X 10 4 3/4 BS, 5/8" studs. Bolted on once for sale. 600.00 pr. plus shipping. As well a pair Weld Pro Stars as new 15 x 10, 5" BS. 300.00 pr. plus shipping .
Steve Teeter STK/SS #620. 360 979 3126 |
Thanks for the input...
I wasn't aware a 10 inch wheel would work, do you have to roll the outer fender lip? |
Liked 213 Times in 85 Posts
My 67 the metal wasn't rolled . Can't hirt . I did make a set of bump stops to keep the downward body travel to keep the car off the tires on bumps & turns . See if you can get a loner set to put on . I run 15x10x5bs
The '67 & '68 Camaros had a much more open outer wheel opening. The '69's have a smaller outside opening. You may have to get creative a little no matter which wheel width you go with. You'll see what's necessary when you do it.
69 Camaro with 8 inch rim with 4.50 backspacing. It needs a 1/4 spacer on the driver's side wheel to give proper clearance.
