Liked 354 Times in 120 Posts
Was going to go to Thunder Valley today, started the stocker up and it would not backup. It has a 200 with auto shift, everything worked when we parked it. Had it out on the hyway for a down and back a few months ago all was fine. 402 329 6795 402 750 0882 Tom
Tom Meyer 5240 SS Stock ??? |
Liked 134 Times in 28 Posts
Tom;
I know next nothing about the GM200 but my guess is a stuck valve. Try draining and replacing the ATF and filter with fresh. When you remove the pan and filter, if you see lots of metal and debris just take it out and see what broke. Chuck |
Typos aside, how many "back ups" on the unit? Did it ever slip when backing up, especially uphill? How many frictions in the low/rev?
One possibility that's easy ..All the rest, out she comes.
Pulled the pan had some stuff on the magnet so we just pulled it. Now who does a good job on 200s in the midwest? We know nothing about this trans or converter so i guess it time to find out. Tom
Liked 280 Times in 139 Posts
Jeff Nibaur in Elma IA.,he went through mine years ago,worked great.He runs a 71 Chevelle in B/SA.I lost his contact info over the years,Chris Knudsen knew him well...gsa612
Liked 1,471 Times in 308 Posts
Tim Wudarzyck, Kansas. Does an excellent job. They run a Stock & Super Stock car. He's up to date on 200's, as good as your going to find.
J.R. |
Got Tylers number? Thanks Tom
Liked 275 Times in 76 Posts
785-842-0865
Well frustration continues, put are trans back in today have reverse and low but shifts to second and then goes away no third. Has a turbo action auto shift. We ended up manual shifting at Madison with a different trans and powering up solenoids. Will not up shift in burnout or pit mode. Are these valve bodies junk? Who can we talk to to make this thing work. Thanks Tom
What was wrong with it the first time? Who fixed that issue?
