Liked 20 Times in 15 Posts
any one have experience in putting MoPar side /axle gears in a Chevy [56-64] Dana posi. they were the same posi units, just different parts inside.
I have a line on those parts. just want to be sure they will really interchange before I move forward. thanks Rod in AZ |
Liked 10 Times in 5 Posts
I heard it was a common practice years ago so they could run 30 splice mopar axles. I know that chevy posi clutches are different than mopars in that one plate (chev) is about .020 or so thicker than the mopar, and the case halfs will not seat against the other. mopar clutches will work on a chev. I did put a set of chev spiders in a mopar.
Liked 780 Times in 194 Posts
Yes. There was an article in either Car Craft or SS & DI in 1967 that detailed the necessary mods. There were specific MoPar axles that could be modified to fit. Today you could buy axles easily. There was a shim kit you could buy from Chevrolet parts that was used to adjust the clutch pack thickness. I did this in the summer of 1968 to a '57 Chevrolet.
Liked 799 Times in 236 Posts
If you're going to use a posi setup, I'd call Tom's Differentials and talk with them.
I remember that some of the differentials has 8 plates and some had 10. The spider gears were also a weak spot but I believe Tom's makes replacement high strength spider gears. They've been doing these '55-'64 style drop outs for a long time...many of the 409 guys use their stuff. Might be worth the call if you're committed to using a posi. -Al https://tomsdifferentials.com/toma.html
"That'll never work....." |
#5 | |
Liked 704 Times in 281 Posts
My first car was a 55 Chevy in 1976. 327 4speed. I broke so many spider gears. As soon as the car wheel hopped bam. If I had only knew at the age of 16 this trick.
We had Chrysler side gears and Henry's Axles in 1970...because we had to.
What are we building here?
I designed a complete kit for running these rears, which I use in my 62. The Dana "powr-lok" design posi unit is available brand new, already prepared with the 30 spline side gears in it.
Also, bearing cap re-enforcement is mandatory.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Liked 172 Times in 81 Posts
[QUOTE=Mark Yacavone;618405]We had Chrysler side gears and Henry's Axles in 1970...because we had to.
Likewise, Chrysler side gears, Henry's axles, shim the clutch pack tight, torque up those weird left hand bolts, then weld the two halves together. Add steel caps and longer cap bolts and it might be good for a few runs with a stick car. Not sure when we first tried this, 67 or 68. Jim Mantle V/SA 6632 |
Liked 320 Times in 102 Posts
I still have a couple of hams on the shelf that have Stahl & Associates heat treated MOPAR posi side gears to go with my Henry’s Axles in my 1962 Corvette
You also need a steel bearing cap and stack the posi plates 1 internal tang and 1 external tang to make it a locker.... I also welded a doubler plate and 1/2-20 nut to the rear of the housing, so I could tighten it up against the cap for strength.... Don’t forget there are 2 types of posi cases, 1 with 90 degree ramps and the other 120 degree ramps... I ran either 3.70’s or 5.38’s on the street back in Brooklyn........
Bob Mulry 7516 STK A & M Motorsports Last edited by Bob Mulry; 07-22-2020 at 03:58 PM. |
