Old 06-30-2020, 10:52 PM   #11
Willyracer
Willyracer's Avatar
Liked 57 Times in 24 Posts
Default Re: Racepak O2 sensor
Thanks Adger
That is the way I always tuned my bracket car for years.
I never had an O2 reading to compare. Some time to
Much info causes a brain overload. Lol
Thanks again to everyone
David
Willyracer is offline   Reply With Quote
Old 07-01-2020, 12:31 PM   #12
Jeff Stout
Liked 708 Times in 285 Posts
Originally Posted by Adger Smith View Post
When you get tired of reading what all the experts say... Go to the track and tune your engine where it is happy.
Best ET and MPH in the conditions available.
Then hook up your gauge and let it tell you what the A/F ratio is.
Your dealing with arbitrary numbers and your engine combination may not be happy with them.
I loved it when I was dyno testing and had customers tell me the EGT and AF had to be certain numbers to make power.
Their engines usually told them something different.
When making power most engines accelerate when slightly rich at peak Tq and run up toward lean at peak HP.
In the car I like slightly rich at the gear change to produce Tq and pull off the gear.
Totally agree. When I started data logging I was rich at gear change. Didn't know any better and went to work on making entire pass stay between 12 and 13to1. As I did the car was slower at 60 to 330 and also at 330 to 660 incrementials. Plugs looked good. Went back with around 10.5 area at bottom rpm of gear change and car came back around. Lesson learned.
Old 07-02-2020, 04:13 PM   #13
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Sometimes it needs a little more fuel to help it recover on the gear change. And often there is no reason at all for what it wants. Engines are like women. They want what they want. LOL
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 07-02-2020, 06:03 PM   #14
KRatcliff
Liked 534 Times in 143 Posts
This is true to a point, but replacement parts don't always cost a small fortune on engines and turning them on is generally pretty easy.
KRatcliff is offline   Reply With Quote
Old 07-02-2020, 06:30 PM   #15
SSDiv6
Especially with VP fuel...
Old 07-04-2020, 04:20 PM   #16
Adger Smith
Liked 880 Times in 311 Posts
Beer VS Tequila
If they run on beer it could be cheaper...JS
Adger Smith (Former SS)
