Liked 53 Times in 17 Posts
Second time in 35 passes rolled the sprag for second gear on the T350 in the SS car! Ideas why?
Liked 308 Times in 103 Posts
I was told not make 1-2 shift in burnout, so I just started burnout in high, and if reverse pattern was told not shift from high back to neutral while moving....
both were hard on sprag.. |
Yep, we do the 2nd to high burnout but on the other end we do go high to neutral.
Liked 167 Times in 81 Posts
I always thought that was funny, engine builders say don't leave it in gear at the end of a run and trans builders say don't shift to neutral
Tim Schmackpfeffer 762 SS |
Liked 55 Times in 17 Posts
From what I have been told if you shift to neutral after the run the trans wont oil good enough coasting so fast. I dont know for sure but understand that it is hard on the motor slowing down in gear too...
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car. |
Liked 99 Times in 49 Posts
Liked 239 Times in 114 Posts
Some of the aftermarket high gear drums have sprags that do not have end bearings . These are no good , the end bearings keep the inner and outer races concentric . Without the end bearings the sprag dog bones will not engage evenly and will roll over in short order .
Liked 1,948 Times in 589 Posts
one reason I stick with a powerglide. They are virtually indestructible. Not as fast as a good 3 speed. But very consistent and reliable. I know I could pick up a couple of tenths with a good 3 speed like a Coan XLT or a Pro trans.
Mike Pearson 2485 SS |
Liked 535 Times in 110 Posts
Another thing. Be sure the trans builder did not remove the accumulator spring. Some do. It will make the shift into second very harsh, which is hard on the intermediate sprag.
Jim Kaekel 3836 STK |
