Old 03-07-2020, 07:04 PM   #11
DG7050
Liked 115 Times in 31 Posts
Default Re: National Records ?
National Opens seem to be the best place to set records since runs at such events don't go into the AHFS data base.
DG7050 is offline   Reply With Quote
Old 03-07-2020, 07:07 PM   #12
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
NHRA really needs to rethink about National Records for sportsmen racing. I bet I’m not the only one that feels there should be an incentive or inducement for setting an E.T. Or MPH record. Something like 20 points for an ET record and 10 points for establishing a new MPH record.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 03-07-2020, 08:05 PM   #13
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
I believe a record is erased and set back to a minimum after 2 years.
So, as ridiculous as it sounds, if a guy wanted to, he could just keep setting a new record, just barely below the min, every time NHRA goes back to the min. That's assuming nobody else wanted to go thru the process, for that class.
Does this sound correct ?
The last Pontiac Stocker I was aware of that held a record was the '71 455HO powered Lemans of Scott Underhill. The record was 10.75, set 7/20/14. At that time, I don't know how many E/SA cars could have set it lower, if the owner had wanted to do it. Don't have a clue how long he held that record, or who had it next.
Name:	Record 7-20-'14 E-SA .jpg
ID:	54165   Click image for larger version
Name:	Scott Underhill .jpg
Old 03-07-2020, 08:08 PM   #14
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
OK so here’s the scenario, you are leading the national championship points by one round the guy behind you has to go five rounds to even get a point instead he decided to borrow Joe blows car that can easily set a record and does so. He just won the national championship when he was five rounds behind you. do you still think that’s a good idea?
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-07-2020, 08:16 PM   #15
MR DERBY CITY
Liked 7,941 Times in 1,520 Posts
I would try to borrow Bob Shaw’s El Camino....
Old 03-07-2020, 08:26 PM   #16
bykr
Liked 167 Times in 81 Posts
Well both drivers had the opportunity to set records. There should be some incentive for performance.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 03-07-2020, 08:28 PM   #17
Keith 944
Keith 944's Avatar
I agree there should be some incentive but the whole points thing could really rattle it up
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 03-08-2020, 02:35 PM   #18
Ed Wright
Ed Wright's Avatar
Used to be 200 points (2 rounds worth) And MPH records were 100. Resetting your own record was half the points.
Ed Wright 4156 SS/JA
Old 03-09-2020, 08:47 AM   #19
rod butcher
Liked 132 Times in 27 Posts
They should put the records back in National Dragster. Taking them out was a slap in the face to all class racers.
Rod Butcher
rod butcher is offline   Reply With Quote
Old 03-09-2020, 11:55 AM   #20
GEORGE PETERSON
Liked 11 Times in 6 Posts
Records are made to be broken, not to expire.
GEORGE PETERSON is offline   Reply With Quote
