Old 01-06-2020, 12:19 PM   #11
Dave Gantz
Liked 251 Times in 125 Posts
Default Re: 1956 Chevrolet Handyman Wagon
Originally Posted by Chad E532 View Post
Paul is my father, this wagon was his first car before he built the sedan for the 1971 season. He took the complete drive train out of the wagon and dropped it into the sedan and picked up a tenth back 50 years ago. Probably be the same tenth slower duplicating his current setup and putting it into the wagon again. The wagon is a natural O car but it would probably make more sense to add a little weight and run P since it is on the high side of O at 15.82 in its original 210 trim.
Chad
You might pick up more than a tenth, todays tires and track prep being what they are.
Enjoying your project...
Old 01-06-2020, 06:24 PM   #12
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by Randall Klein View Post
FYI
Paul Lindberg in Minnesota racing a '56 Sedan in N/SA
265/225/216
12.37 in M
12.28 in N
Does the 1956 engine have different pistons than the 1955?
Old 01-06-2020, 07:31 PM   #13
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
The picture of the car black was at the old North Star Dragstrip. We had a lot of fun racing there.
Old 01-07-2020, 10:10 AM   #14
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
The '55 pistons are flat tops with no valve reliefs. For '56 and 57 the 265 pistons had valve reliefs added.
Chad E532 is offline   Reply With Quote
Old 01-09-2020, 11:27 AM   #15
Lyn Smith
Liked 1,000 Times in 202 Posts
The 55 265s and early built 56 265s had flat top pistons, but GM stopped production of them mid 1956. You could not even order them from a dealer from mid 56 on.The part number was discontinued. If you build a 55 Stocker you must use the flat tops, and you must use a cam with 230 or less duration because of no piston to valve clearance. NHRA let the Jr Stockers use the valve relief pistons back in the 60s,and early 70s,but not now.
Old 01-09-2020, 04:34 PM   #16
Chad E532
Chad E532's Avatar
Continuing with the tear down.
Mid 70's suspension technology at its finest.
Name:	20200108_195151 resize.jpg
Old 01-09-2020, 06:26 PM   #17
Jerico !
