#131 |
Liked 20 Times in 13 Posts
Bob bales grand am is chev powered. Let us not forget the 70 ra4 gto out of div3 SS/IA. CURRENT CAR sorry i can't recall his name
#132 |
Bob bales grand am is chev powered. Let us not forget the 70 ra4 gto out of div3 Bill Eadelis current car
#133 |
Liked 5,120 Times in 1,951 Posts
David Sidlo , GP with a 389 , AFB..Division 4 ..Practically your neighbor ;-)
#134 | |
Liked 747 Times in 362 Posts
But hey, that's what a lotta cars ran back in the '60's & '70's. So, you pull Jack Mullin's engine out of his wagon & put it in a GT car, it should run the index or better, I figure. Looked up a few '63 389's, with AFB. 1 has a 250hp factor. Would be interestig to know just which 389 he's claiming. OK, the 1st time I pull up his name is in 2018 at the Houston div race. He's #27 @ -.782. Listed as a '97 Firebird. So does that car also have a 389 or any Pontiac engine ? https://www.dragracecentral.com/DRCStory.asp?ID=336513 Or was the 389 powered car run several years back ? https://www.dragracecentral.com/DRCStory.asp?ID=324172 https://www.dragracecentral.com/DRCStory.asp?ID=322961 Last edited by oldskool; 01-04-2020 at 11:35 PM. |
#135 |
Thanks ! I'll remove him from the list.
#136 |
Last pic I have is from '19 US Nats. He's running SS/MA.
Wonder what you'd have do to his car to run GT, without makin any engine changes ? I know very little about GT rules. Can you just tech in as a GT car, even tho you've made no changes ? Last edited by oldskool; 01-05-2020 at 12:43 AM. |
#137 | |
The big question is how did he get away with the Mullins motor? It's stick shift only.
#138 | |
I'm not familiar with all the 389 combos. Have no idea which engines came with which trans. But, assume that out of all the years a 389 DID come with an auto, maybe you could find one that would make a decent GT engine. The only 389 cars I know of that have been running lately are Norman Warling's '62 Cat Stocker & Bob Michael's '62 GP Stocker. I think they both run Tri-Power. Last edited by oldskool; 01-05-2020 at 12:49 AM. |
#139 |
62 tripower 389 318hp was defactored to 275hp. As for ss to gt nothing has to change but the gt cars at same hp to weight index is .05 faster most guys do it to avoid heads up runs
#140 |
Liked 902 Times in 237 Posts
Bob Bales used to run a older Pontiac Firebird with a 455 Pontiac engine also
Don Kennedy 7701 SS |
