Old 11-14-2019, 10:40 PM   #31
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Default Re: What Stock rules would you change?
Working brake lights from a mandatory, non-bypassable switch. So we can see who is hitting the brakes and when. Plus it could eliminate line lock and launch control starts. Brake lights should be on when you start, and not on until AFTER you cross the stripe!
Overkill is Under-rated
stocker396 is offline   Reply With Quote
Old 11-14-2019, 11:15 PM   #32
Jeff Stout
Liked 704 Times in 281 Posts
First part of this idea would make fast cars have an advantage.
Old 11-15-2019, 12:28 AM   #33
Bobby Fazio
Bobby Fazio's Avatar
Allow TruStart and crank triggers. Get rid of E-shift.
'65 Mustang SS/L & L/SA
Old 11-15-2019, 01:48 AM   #34
Liked 5,125 Times in 1,953 Posts
Originally Posted by Bobby Fazio View Post
Allow crank triggers.
Allow more non -Stock electronics?
Get rid of E-shift.
Dis-allow non- Stock electronics?
Old 11-15-2019, 11:24 AM   #35
cmracing
Liked 62 Times in 29 Posts
Allow the LT1 engines to toss that Opti Junk in the garbage where it belongs and either do CNP or a "normal" distributor. They are already allowed a crank trigger and aftermarket ECM's.
cmracing is offline   Reply With Quote
Old 11-15-2019, 11:44 AM   #36
Race Clean
Liked 129 Times in 53 Posts
Though I'm generally against anything turning a Stocker into a SS'er I would like to see Crank triggers allowed, especially now when more and more Cars/engines that have modern fuel/spark systems find the way into the mix of older cars it would be nice to at least be able to eliminate the irregular timing you often get with more normal setups going through timing chains(of more and more questionable quality) dist.gears etc.
Race Clean is offline   Reply With Quote
Old 11-15-2019, 01:31 PM   #37
Mr Clean, You 're probably right. You can't win a thing with that irregular timing.
Oh, wait. Here's three different 305, 4bbl. Malibu wagons that won Divisionals this year, with irregular timing..How do you suppose that happened?
Old 11-15-2019, 02:01 PM   #38
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
1st round at pomona, 2 races trustart would have changed the outcome
U/SA
79 Mustang
Old 11-15-2019, 03:08 PM   #39
james schaechter
Liked 1,435 Times in 299 Posts
I don’t think you can draw conclusions from current races without really knowing more than what is on line. If tru start was in play, surely any racer would know that and adjust how they drive race etc.
James Schaechter 3163 STK
Old 11-15-2019, 06:39 PM   #40
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: What Stock rules would you change?
Originally Posted by Mike Mans View Post
Well that's an interesting idea. Do you really need much more seat pressure than this? Seems kind of wasteful on a lot of friction based valvetrain motors to run so much spring pressure...
The non OEM lifters cost a bunch to survive the out of this world spring pressures !
