Old 09-19-2019, 02:19 PM   #11
Mike Gray
Mike Gray's Avatar
Liked 704 Times in 203 Posts
Default Re: 4th Gen F Body V6
FWD version? Okay I'm not much of a GM guy the Camaro I was working on was a 2000 3.8 V6 is that a considered a 4th Gen?
Old 09-19-2019, 05:06 PM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Gen 4 F-body went from 1993 to 2002 . The 2000 F-body has one version of the 3.8L , it's rated at 200 hp . In the classification tech sheets there are two 3.8L engines listed for the 2001/2002 F-body . Looks like the only difference is the compression ratio. The higher compression engine is rated at 200 hp . The 3.8L in the FWD Monte Carlo is rated at 200 hp.
Old 10-17-2019, 10:36 AM   #13
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
I am still considering swapping my LT1 for the 3800 (3.8L) engine in my 95 Camaro. I cannot find anywhere whether the LT1 and RWD 3800 has the same trans mounting configuration. Also will the 3800 work with the K member that I have? Thanks.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
Old 10-17-2019, 12:54 PM   #14
Liked 5,143 Times in 1,964 Posts
No . It has the FWD pattern. You'd need a not too common FWD pattern 200 case, used in early 2.8 or 2.5 applications..Good luck finding one.
I believe the cradle will work with the long V6 engine mounts.
The 185 hp version looks better to me on paper, if you're not in a hurry..No pistons approved.
Old 10-17-2019, 06:44 PM   #15
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
K member would work but would require custom motor mounts. V6 cradle is different than LT1 and LS1 is also different.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 10-17-2019, 07:03 PM   #16
ss3011
ss3011's Avatar
Might have one of those 200 THM cases , if you are interested .
Old 10-17-2019, 10:19 PM   #17
Darrel Goheen
Thanks for all the help everyone. I guess the first step after deciding to do it is finding an engine.
Old 10-17-2019, 10:21 PM   #18
Darrel Goheen
Default Re: 4th Gen F Body LT1 to V6 Swap
Thanks. I'll let you know if I need one and can't find one locally.
Old 10-17-2019, 10:25 PM   #19
ss3011
ss3011's Avatar
I have an engine too .
