#21 |
Liked 11 Times in 4 Posts
Well I don't think I've ever seen a stocker oil the track. However at the Dutch on Friday afternoon a blue 69 camaro did a moonshot wheelstand and upon landing pitched out what appeared to be the trans blanket. That was something new in my world.
![]() Mike Z |
#22 |
Liked 6 Times in 2 Posts
We had a Jr. Dragster oil the track this year. Last weekend it was a Stick car that split the trans case. Numerous rear end explosions, auto trans blowups, oil line leaks and rad hose failures. I'd think engine failures are becoming a lot less with improved and accepted parts.
I'm all for safety but how many Diapers should be on a race car anyway. If you want to run one then fine, but I don't, probably can't fit one and don't think making them mandatory is a good move.
Dale Posnick |
#23 | |
Liked 3,300 Times in 300 Posts
Does not look like 1969 Camaro to me, but maybe more than one car pitched its safety gear off mid track. First time I'd ever seen this happen. |
#24 |
Liked 684 Times in 289 Posts
#25 | |
![]() Mike Z |
#26 |
Liked 598 Times in 164 Posts
We had a D1 race where 3 Stockers oiled the track during the first Qualifying shot. I myself have oiled it twice. First when I bought the car I was the first car down the track at No Problem and spit a rod out at bat mid track broke the trans driveshaft and pinion yoke too. Shut the track down for almost 2 hours. So yes it does happen.
#27 |
Liked 10,906 Times in 2,255 Posts
After looking at the B-E body engine, steering, and headers on my stocker, it would be a lot of work and expense. The drag link runs real close to the sump and the bottom of pan, this could be a potential crash if the Kevlar blanket jams the steering. A motor plate would not help the steering situation. A tray might work until a big wheel stand. When that happens on my car it bends the oil pan against the pickup, and bends the transmission pan. The oil pan I have to fix before I make the next run. If new ss headers are needed to complete the ORD I will be done.
All of a sudden cutting bait doesn't look so bad. Last edited by Larry Hill; 10-07-2019 at 07:11 AM. |
#28 |
Liked 93 Times in 29 Posts
Stock eliminator- entry level. Mandatory belts every 2 years, mandatory approved collector tethers, now mandatory diapers? Sad to see the so-called evolution of this class.
#29 |
Liked 695 Times in 206 Posts
On a Hemi car with the drag link going through the oil pan (some Chevy ll’s also), I do not know how you could fit a diaper effectively. If NHRA allowed an aftermarket K frame, it might be possible.
#30 | |
Liked 287 Times in 146 Posts
I wasn't real fond of putting it on, but when the rules require it (I ran the car in S/ST a few times...ex-SS car), you find a way to make it work if you want to race. While the Jeg's diaper doesn't provide the best fit, I can only imagine how much better the job would have been had I used something that was designed for the car. |
