#11 |
Liked 689 Times in 198 Posts
FWD version? Okay I'm not much of a GM guy the Camaro I was working on was a 2000 3.8 V6 is that a considered a 4th Gen?
#12 |
Liked 239 Times in 114 Posts
Gen 4 F-body went from 1993 to 2002 . The 2000 F-body has one version of the 3.8L , it's rated at 200 hp . In the classification tech sheets there are two 3.8L engines listed for the 2001/2002 F-body . Looks like the only difference is the compression ratio. The higher compression engine is rated at 200 hp . The 3.8L in the FWD Monte Carlo is rated at 200 hp.
#13 |
Liked 70 Times in 31 Posts
I am still considering swapping my LT1 for the 3800 (3.8L) engine in my 95 Camaro. I cannot find anywhere whether the LT1 and RWD 3800 has the same trans mounting configuration. Also will the 3800 work with the K member that I have? Thanks.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#14 | |
Liked 5,125 Times in 1,953 Posts
I believe the cradle will work with the long V6 engine mounts. The 185 hp version looks better to me on paper, if you're not in a hurry..No pistons approved.
#15 |
Liked 228 Times in 70 Posts
K member would work but would require custom motor mounts. V6 cradle is different than LT1 and LS1 is also different.
#16 | |
#17 |
Thanks for all the help everyone. I guess the first step after deciding to do it is finding an engine.
#18 |
Thanks. I'll let you know if I need one and can't find one locally.
#19 |
I have an engine too .
