#61 |
Liked 11,000 Times in 2,263 Posts
I will take some pics of the Cuda when we get to Great Bend and post them on that "Live" from!
Patsy |
#62 |
Liked 3,244 Times in 986 Posts
Patsy, it was great to see the Cuda running on Warren’s broadcast. Hope you and Larry have gone on YouTube and watched it.
#63 |
Doing normal maintenance on trans, oil and filter change, I found broken brake line on rear housing. Cause of failure; vibration and improper mounting. So now going into the fourth round I will have a new brake line and fresh brake fluid. And a test and tune day to make sure everything is OK.
Moral of the story, be safe and check you stuff. |
#64 |
We left yesterday to travel to the site of the first Nationals, Great Bend Ks. Got as far as west of Wendzville Mo. on I-70. We got lucky and pulled into a rest area at 9.30 pm and found a spot to park and put the bedroom slide out. I sure hope I didn't use all my luck on this trip in a rest area.
#65 | |
Liked 101 Times in 52 Posts
That's why I always suggest the drivers go visit the safety trap at the end of the track before running. Glad you caught and repaired it, good luck and safe travels. |
#66 |
Liked 431 Times in 224 Posts
Great catch although, if you're going to lose your brakes somewhere, Great Bend would be a pretty good choice.
S/ST 51 S/C 53 |
