#11 |
Liked 799 Times in 236 Posts
Agreed. But like the heads...how would they determine what's 'stock'?
"That'll never work....." Last edited by Alan Nyhus; 08-14-2019 at 06:38 PM. |
#12 |
Liked 81 Times in 35 Posts
Sounds like Wesley will be at Indy.
Greg |
#13 |
Liked 325 Times in 50 Posts
I think Wesley will be at Indy.
Jeff Teuton 4022 STK |
#14 |
Liked 2,718 Times in 958 Posts
Moved to a new thread.
#15 | |
Liked 88 Times in 43 Posts
At the Sportsnationals, in the late 70's, there was a sign posted on the return "road SS/AA turn here". NHRA did not, at that time, disqualify any cars. They did learn a LOT about the cars by having them all sitting at the same place, at the same time. I expect it allowed NHRA to determine the cars that were constructed to the extremes of the rules and address technical discrepancies from there. The FS cars that come with CNC'd heads certainly need to be held to a more finite set of standards than 60's and 70's products. I have a story about C/SM and Chev 461 heads that's too long to relate here. |
#16 |
Liked 67 Times in 28 Posts
Here is a real simple scenario that could play out and potentially cover a lot of cars in a reasonable amount of time. After the last qualifying run on Wednesday park all the cars in an area near the teardown barn and ask everyone to remove their carburetors or throttle bodies. The tech officials could take one of the readily available high-quality video probes and take a look down the intake manifolds for anything that may be suspicious. Depending on the time available, the suspicious intakes could be pulled then and inspected or sealed and those cars will get an automatic invitation to teardown. It’s clear there is a new Sheriff and Deputy in town!
#17 |
Liked 280 Times in 139 Posts
On the older cars they look at the "texture" of the cast,and run a finger in the runner.If it don't look or feel right your gone.Red Anderson(div.4) had one of those magic fingers. gsa612
#18 |
Liked 43 Times in 14 Posts
Be thankful they're taking this a bit more seriously. They could solve this problem with a stroke of their pen. Imagine a rule book entry like "stock intake and exhaust valve diameter required; any other head modification allowed" and "any intake manifold or modification allowed as long as the material matches the orginal and it fits the stock carb".
I think more races are won and lost on the drag strip than in the teardown barn. |
#19 | |
Liked 1,428 Times in 296 Posts
Wow you really don’t understand class racing...
James Schaechter 3163 STK |
#20 |
Liked 198 Times in 79 Posts
From what I have been told NHRA is trying to bring things back under control based on a incident that happened in the recent past. Wesley will lead in this endeavor.
Mike Fuller 396 STK 3961 SS |
