Old 08-08-2019, 12:35 PM   #11
DonatoEng
Liked 8 Times in 5 Posts
Default Re: Spare tire
I had a slick go flat at the end of a run at Indy and pulled over on the return road, opened the hatch pulled out the spare and jack and proceeded to change the tire. This was all before the scales.
Never seen so many Tech guys come flying up the return road to watch me and escort me to the scales.
John Donato Stk / SS 3435
DonatoEng is offline   Reply With Quote
Old 08-08-2019, 01:49 PM   #12
stage1scott
stage1scott's Avatar
Liked 109 Times in 44 Posts
It's hard to believe what memory cells get jarred by different subjects in here-back in my stocker days, early-mid 70s,I recall a story of a very fast 71 454 Chevelle in Div 1 with a 200 lb spare mounted in the trunk-this was way way before weight boxes and changing classes up or down was legal and the accepted way to do it. he was bounced from the event but no further recriminations except don't show back up with that spare.
Old 08-08-2019, 02:07 PM   #13
stage1scott
Old 08-08-2019, 04:22 PM   #14
Pete Lanciers
Pete Lanciers's Avatar
Liked 627 Times in 156 Posts
Scott, I seam to have a similar recollection from E-town was it a Blue & White convertible running SS/EA?
Pete Lanciers
PAL Automotive Racing
Stock 7801
Pete Lanciers is offline   Reply With Quote
Old 08-08-2019, 08:17 PM   #15
james schaechter
That’s funny! They must have heard the one about the Cobra Jet that went 1.20 under and lost the spare tire before getting to the scales. LOL
James Schaechter 3163 STK
Old 08-08-2019, 08:59 PM   #16
Dave Gantz
Liked 251 Times in 125 Posts
Originally Posted by Lew Silverman View Post
Is there a requirement to carry a spare tire? I've never seen anything in the rulebook, although if you're looking to add some "legal" weight to your car that may be one way. I've heard stories of folks who added things other than air to the spare, and tech inspectors who aggravated hernias inspecting them!
Let's go back to this. Is it a requirement to have a spare? Or has it been a way to add weight in the past that's not needed now?
Old 08-08-2019, 10:42 PM   #17
james schaechter
In stock it is not required, but can be used as additional weight beyond the weight box. One thing Travis used to look at was that it was at least something that you could bolt in the car. Correct bolt circle etc. we use a bumper jack and the original hold down on our 66 Nova sometimes when we run a heavier class.
Old 08-09-2019, 03:54 PM   #18
stage1scott
Right church wrong pew--as far as I knew, it was the hardtop in SS/FA that had the heavy spare, both probably utilized it!
Old 08-13-2019, 05:56 AM   #19
Liked 10,927 Times in 2,258 Posts
The spare in the Cuda was in the middle and high and in-between the two wheel wells. Also had jack, lug wrench, bumper adapter, and hold down all in the proper place.
