Liked 698 Times in 216 Posts
What's the difference between a D06 compound and a D07 in a 9.00X15X30 Hoosier slick?
Liked 125 Times in 33 Posts
Greg,
Believe that the D07 is the "firmer" compound for stick applications. At the bottom of the Drag Racing section of the Hoosier tire specification sheet, they illustrate a spectrum of compound designations from soft to firm. Last edited by T Ames; 07-11-2019 at 08:14 PM. Reason: added info |
Liked 280 Times in 139 Posts
Those would be bias ply,radials start with a "C".With Hoosiers the lower the number the softer the compound.The 30.0 X 9 # 18200 seems to come in a DO5 or DO7.While the 29.0 x 9 #18160 comes in a DO6 or DO7. gsa612
Liked 431 Times in 224 Posts
The 9" radial comes in C06 or C07. The C06 is a little bit softer, and is only available in the tires designated as 'lightweight'. I assume that lightweight also means 'might be a little quicker but won't last as long'.
I always use the C07 18210, and love that tire. 125-150 passes.
S/ST 51 S/C 53 |
