Can anyone recommend a set of exhaust gaskets that work on a small block Chevy with hooker adapter plates.? Tried several over the years haven't found anything that doesn't leak.
Thanks |
Liked 398 Times in 153 Posts
Remflex. They won't leak.
Phil Molski PMR Performance S/C 1623 |
Liked 27 Times in 19 Posts
If you have good flat flanges, Hi Temp silicone works great.
Liked 778 Times in 142 Posts
Fred, if you’re talking about between the adapter and the head, I don’t use a gasket and have had zero problems. Just lightly butter it with red rtv and bolt the plate onto the head with no gasket.
For between the plates and the header flange I really haven’t had a problem with mr gasket typical gaskets. BUT I have learned after you first fire up the engine and get em hot for the first tine, come back and snug up on the header bolts. You’ll typically find em a bit loose and if you don’t snug em, after a dozen passes they’ll leak out and burn up. |
Liked 1,072 Times in 379 Posts
We made our own. And have been using the same identical gaskets for over a decade. Must have been on and off 50 times. No leaks what so ever. I have to give brother John the credit. He found this material that they used where he worked. ( Gore-Tex) They used it in the boiler rooms. We just took a small sheet of it, found a gasket we liked and fit, and copied at a cad table with a knife blade on it. I know why nobody sells them, you would never sell a second set !
This is a second set we cut out by hand but have not needed …...
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 06-22-2019 at 11:29 AM. |
#7 | |
Liked 13 Times in 7 Posts
Thanks for the info. I let my Fingers do the walking on the net. I might have found a supplier near me in AnnArbor, Mi. Thanks Again, |
Jeff,
Thanks they have it at Mc Master Carr. |
Liked 8,240 Times in 1,540 Posts
Silicone is a mess. And you have to clean it off every time you take them apart MJ. Call me lazy but I like using reusable gaskets that seal as good as silicone without all the disadvantages ..
Jeff Niceswanger 3740 SS |
