Old 04-19-2019, 09:26 AM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Legal ways to light car.
My 1969 Impala will be in reassembly stage.
Need a garage to complete it.
Wanted to know how to handle bumper braces.
What is considered legal lightening?
Are there any aluminum components that would work?
Like a supply of hardened alloy bolts/nuts?
Old 04-19-2019, 09:33 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Legal ways to light car.
Most effective way on a early GM car is to remove all sound deadener, insulation, and extraneous pieces. Then use aftermarket seats, aftermarket disc brakes and light wheels. The expense of alloy bolts, etc. is way too much for the overall weight reduction. You might save 3 lbs if you replaced every no critical body bolt with aluminum or titanium.
Old 04-19-2019, 12:02 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
I also run a lightweight lithium battery. It weighs 8 lbs. saves about 30 lbs. brakes were a huge weight savings. 60 lbs lighter than the drums. Braking is way better as well with the aftermarket light weight brakes.
Mike Pearson 2485 SS
Old 04-19-2019, 12:13 PM   #4
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Smile Re: Legal ways to light car.
Gasoline and a match !
Old 04-19-2019, 01:23 PM   #5
CMcAllister
Liked 920 Times in 259 Posts
We replaced stock seats and mounts with aluminum Jaz and fabbed Ch-Moly mounts in a 72 Chevelle and saved right at 80 lb.
Old 04-19-2019, 03:44 PM   #6
Jeff Jewell
Jeff Jewell's Avatar
Liked 171 Times in 36 Posts
Talking Re: Legal ways to light car.
Billy Nees once told me "look for 50, 1 lb items, not 1, 50 lb item"...
Old 04-19-2019, 04:21 PM   #7
Dan Fahey
Dan Fahey's Avatar
OK... FWIW
I lost 20 pound of wrinkle filling fat last year..!
Think that helps.
The body right now is a Shell on a rebuilt Chassis.
Did have the floor sprayed with a sound deadener.
Have the Stock Carpet and Headliner.
What are the Best Adjustable Seats?
It has the Stock Drums on all fours.
What Disk Brakes are recommended for this car?
What Booster is used for Power Brakes?
Lightweight Lithium Batteries, good idea.
Is it useful to have two batteries? (one in Trunk)
What about wheels?
Old 04-19-2019, 05:21 PM   #8
Lee Valentine
Liked 319 Times in 68 Posts
Light seats,aircraft carpet,light battery,mini alternator,mini starter,light wheels,aftermarket brakes. My friend runs a 66 Biscayne and has Wildwood brakes,stops from 130 mph weighs 4000 lbs.
Lee Valentine 1661 STK
Old 04-19-2019, 06:09 PM   #9
Mike Pearson
I use a single core aluminum radiator. Alum is lighter than brass. Also the single core reduces the amount of water in the system. My system holds just over 2 gallons. Small fuel cell. 3 gallon cell and only haul a couple of gallons of fuel in the car. A gallon of fuel is about 7 lbs. water is about 8 lbs per gallon.
Old 04-19-2019, 06:10 PM   #10
Liked 10,738 Times in 2,234 Posts
Remove all sound deadener, look in doors, 1/4 panels, and top. Remove stick out on bolts, big ones first. Lighter steering wheel, new glass is thinner sometimes. Put the correct gage wire for each load, remember bigger is heaver. Remove all unnecessary wire. Look in the rule book.
