Old 02-07-2019, 11:57 AM   #131
J&S Racing
Liked 319 Times in 82 Posts
Question Re: 69 Camaro B/S
Not to let that Florida guy have all the fun I’ll get a update in..
Repainted the cage (3rd time), replaces all the weather seals and small gaskets. Door handles, marker lights, bumpers and tail lights all re installed. I started on the rear carpet, just need a proper pipe to use Todd’s method of burning the cage holes.
I’m a little pissed the body man didn’t drill the 396 fender emblem holes in the correct spot but it is what it is. I’ll come up with some solution as I can’t live with it.
UPS wearing a path in the driveway this week!!!!
1st off a big shout out to Marty from Rinehart performance. The days of dealing with Santhuff direct are long gone but Marty was great to deal with and spent the time to make sure I was getting exactly what I needed. 3mo later the missing link has arrived.
Front rim and tires also arrived
Pressure plate and bellhousing FINALLY came back. They replaced the pp fingers and did a little machining on the bell for the fork. We were able to start indexing, ended up .001 out on the parallel but 24 thou out on the concentric.
Probably the most important delivery was the RobbMC performance offset dowel pins. Another vendor that was great to deal with!! Someone answered the phone late sat afternoon and I had the dowels by Monday.
Hopefully stab the motor this Sunday
Old 02-07-2019, 02:46 PM   #132
Nmbr1GMfan
Default Re: 69 Camaro B/S
Great progress, looks fantastic.
Todd Greene
Old 02-07-2019, 10:59 PM   #133
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
That is a Beautiful car sir..
It brings back a lot a great memories of when I was building mine.
Marty is great to deal with.
Keith
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 03-03-2019, 09:39 PM   #134
J&S Racing
Motor and trans, back in.
I’ve been messing with the clutch fork and linkage. I have a few questions for any of the stick guys following my build.
Where should I run the spring off the fork? Factory it looks like there’s metal extension rod that connects the spring to the motor mount. I’ve also seen where guys attach a hose clamp to a header tube..
Throwout bearing to pressure plate finger clearance?? I’ve read 1/8” to 1/2”
Where is a good place to start with air gap? From the info I gathered I’m thinking of starting with .050
Old 03-03-2019, 11:14 PM   #135
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Air gap .050" you may be able to reduce, and TOB to levers 1/4" to 3/8".
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-04-2019, 03:06 PM   #136
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
I've got a tab welded to the headers for my spring. .050" air gap is a good starting place. You might go a bit more if you want room to adjust your reaction time in the future.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 03-04-2019, 08:11 PM   #137
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
did you replace your stock linkage with heim joints from the pedal to the fork ? that's an upgrade worth doing
as mentioned .050 is a good place to start ,also TOB to levers should be no less than a 1/4 as for the amount of counter weight will affect how close the fingers comes to the bearing at high rpm,,
gmonde
nice build !
Old 03-04-2019, 08:56 PM   #138
J&S Racing
Thanks guys!!
[QUOTE=gmonde;583884]did you replace your stock linkage with heim joints from the pedal to the fork ? that's an upgrade worth doing
gmonde
I am replacing the linkage. Think I need to take about 3” out of the top bar but it’s getting there.
Old 03-06-2019, 03:51 PM   #139
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
My spring runs from the bottom of the dash to the pedal, for what it's worth.
Paul Merolla is offline   Reply With Quote
Old 03-06-2019, 09:11 PM   #140
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
I have the same. I also had a spring from the fork to the other end of the rod where it attaches to the Z bar to prevent the rod from popping off the fork. Since then though I had the fork modified to attach the rod with a rod end. Also, keep in mind if you are using a spacer between the block and bell for clutch clearance, that will give you more room for throw out bearing clearance. I use the shortest throw out bearing I could find available from NAPA. I can get you the number if you want. Are you planning on the Maple Grove Divisional?
Good luck with the rest of the build!
Joe Martens AA/Stock 3969
Joe Martens is online now   Reply With Quote
