Liked 24 Times in 17 Posts
I am not sure if I am over looking it in the rule book or not. Is there a certain amount (size) area it must cover? I bought a Racequip 15x18 mesh/ribbon hybrid with the straps for the door bar and spring loaded upper rod. Car is a 66 GTO and the net looks kinda small.
I tried to upload a pic but some reason keeps timing out. So is there a rule for the size? |
Liked 920 Times in 259 Posts
No. No specific dimensions. "...designed in an attempt to protect the driver and avoid contact with track surface or guardwall." One of those areas where it depends on whose looking at it. I like to use custom nets made for the particular cage configuration. I make it reasonably long enough so that it comes up beyond the elbow far enough to keep the arm in the car. So far, so good.
