Liked 7 Times in 5 Posts
Are there any coils out there for a 7AL-2 that will do the job? MSD 8261 is over $200. According to MSD a lot of coils won't work as well with a 7 series MSD.
Liked 759 Times in 379 Posts
8201
Liked 8 Times in 6 Posts
My old coil died. Just put an 8201 in the car and it runs like it should. I have a 7AL2 in the car.
Raul |
After looking at the 8201 went in the garage to check on some coils I have and sure enough I already have an 8201. Will check it out and see if it is still good. Started working on my Max Wedge last summer after being stored since 1993. Hope the 8201 is still good, as saving any money is nice.
Liked 692 Times in 205 Posts
I have an 8251 MSD Coil for sale, it works with all 7 series msd boxes.
Liked 805 Times in 341 Posts
I have used the MSD 8201 with 7ALs for years with no problems.
Liked 314 Times in 177 Posts
MSD recommends the 8261 coil with the 7AL-2 box, ( the big one ). But I'm sure you will find several racers that have used the 8201 ( the small one ) with no differences, myself included.
Liked 336 Times in 183 Posts
8261 is recommended for short spurts like in Comp Eliminator otherwise it gets too hot and becomes not as effective ---8251 is just slightly less on output than a 8261 recommended in most cases where the engine is run for longer periods of time such as in Stock/Super Stock---8201 coil is a good coil nothing wrong with it but if you want to get maximum efficiency from the ignition system I would look at the 8261/8251 as opposed to a 8201--FED 387
As FED387 pointed out the MSD 8251 is an excellent choice for use with MSD 7, 8, and 10 ignition boxes. This coil runs cool and is the same price as the 8201. I have one on my pro-street SBC and it runs for hours without overheating!
