Old 02-03-2019, 04:08 PM   #1
odds&ends1762
Default Legal Heads for SS/modified
So I acquired a couple new combination possibilities. One is a 315" sbc that was originally in a C/EA car in the early 90's. Has Pontiac aluminum heads and composite Intake from Brandywine. Its all fresh, just old technology and it was cheap enough to try it out. I believe Brodix cast them back in the day for NASCAR or something. Are these a legal head for say SS/BS or CS? Also, I have a top end complete SB2.2 for this shortblock after I change the necessary components. I was also wondering where that would fit in. If It would be legal in BS or would I have to go into say BM? I have sent a email to tech, but I have not received an answer. Just curious if anyone could help me out.
Thank you
Cory
odds&ends1762 is offline   Reply With Quote
Old 02-03-2019, 05:04 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Legal Heads for SS/modified
SS/CS is cast iron in line valve heads only. Aftermarket heads need to be on the NHRA Accepted Product List. GM and Pontiac are listed separately so I don't know if you can run Pontiac heads on a Chevy. The national record holder in CS is a 302 Ford running NASCAR iron short track heads. They aren't listed but have a factory part number.
Aftermarket aluminum heads, inline or canted, are allowed in SS/BS. Watch out for the Hancock and Lane car from D6 if you build this.
EDIT: I had difficulty getting responses from tech out here on the West coast for Super Stock Modified classes too. I didn't go ahead with my build until I found the Canadian car I referenced above on Facebook, CR and in the NHRA record book. It's a weight to HP group with few engine and valve restrictions.
Dale Shearon
68 Mustang 6394
Old 02-03-2019, 05:36 PM   #3
LB Racing 3179
The Pontiac heads were made for the small block Chevy and are legal in Modified. I use the Buick head on a small block Chevy which is legal in SS Modified
LB Racing 3179 is offline   Reply With Quote
Old 02-03-2019, 05:49 PM   #4
LB Racing 3179
The Aluminum heads would be legal in SS/BS.
Old 02-03-2019, 06:43 PM   #5
SSDiv6
Can run SS/BS with either cylinder head, or run SS/AS with the SB2.2.
Can also run SS/AM thru SS/FM with both heads.
Canted valve allowed also in SS/AM and SS/BM.
SB2.2 is a splayed valved head, not canted.
Old 02-04-2019, 03:52 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
I think the 2016 Div 4 SS champ ran a small cu in SB.2 engine in SS/BS.
Two sets of headers came with the car. Looks like a 15-18 deg set and an SB.2 set.
Adger Smith (Former SS)
Old 02-04-2019, 08:58 AM   #7
R Lowry
Liked 2 Times in 2 Posts
SB2 is a canted, not splayed.
R Lowry is offline   Reply With Quote
Old 02-04-2019, 09:44 AM   #8
odds&ends1762
Thank you for all your replies. I really appreciate the info. Now to get it together and make some noise
Old 02-04-2019, 02:30 PM   #9
SSDiv6
He is asking about the SB2.2, not the SB2.
SB2 valve angles are 12° x 4° Intake and 8° x 0° Exhaust and considered Canted.
The SB2.2 valve angles are 11° x 4° Intake and 8° x 0° Exhaust and considered Splayed with all the intake ports pointing towards the center of the cylinder head.
The 8° Exhaust valve angles towards the intake manifold just like a normal wedge cylinder head.
Old 02-04-2019, 05:50 PM   #10
R Lowry
Thanks, did not know that!
