#11 | |
Liked 165 Times in 59 Posts
I cant remember for the life of me ,, internet search is coming up short my lift on the cam is .457 installed Height (in): 1.880 in. Seat Pressure at Installed Height (lbs): 155 lbs. Open Height (in): 1.280 in. Open Pressure (lbs): 377 lbs |
#12 |
Liked 397 Times in 153 Posts
Garret -
If you go down .050 (to 1.830) you should have 173 seat, but your open pressure will only be a bit over 340. The 377 is at .600 lift. I believe you will need different springs. Phil
Phil Molski PMR Performance S/C 1623 Last edited by pmrphil; 12-10-2018 at 09:29 AM. |
#13 |
Liked 237 Times in 126 Posts
Your spring info matches the PAC 1220 beehive spring. Is it this type of spring? It sounds like you want to change the rate and pressures of a spring you have to a spring you want and I don't think it works that way. You can change the seat and open pressures by changing the installed height but the spring rate is dialed into the spring in the manufacturing process. This spring installed at 1.780 with a .457 lift would give pressures of 192 and 362. You can tweak out the IS until you have a seat pressure of 170, but the open pressure will move in the same relationship that 192 is to 362. That's the spring rate doing that.
#14 | |
I checked the pressure before I installed them and they where around 170-180 @ 1.780 installed spring height, the PAC 1220x spring is the next option but it will have to much spring pressure Installed Height (in): 1.900 in. Seat Pressure at Installed Height (lbs): 160 lbs. Open Height (in): 1.250 in. Open Pressure (lbs): 400 lbs. thanks for the reply's ,much appreciated ! Last edited by gmonde; 12-10-2018 at 08:01 PM. |
#15 |
Liked 280 Times in 139 Posts
The Pac 1220X spring shows 160 lbs seat press.at 1.900 and 400 lbs open at 1.250 which is close to coil bind.If you subtract your lift of .450 from the 1.900 your at 1.450 open.That may give you only 360lbs press.You need to find a "short" spring with your low lift that will give you the open pressure your looking for.Even if you do find a long spring that gives you the numbers, but is .300+ from coil bind your going to have valve stability issues. Have you looked into Comp cams ?. gsa612
#16 |
What's the application here? It doesn't really make sense to talk pressures when we don't know what is being asked of the engine. I run PAC 1427 springs - conical for a BBC - in a SBF with NASCAR type iron heads. Stuff gets mixed up when all you want is GO...
Note: A PAC 1409x at 1.8 will give you pressures of 175/384. I'd give up on a 1.78 IS, it's too hard to shim to. 1.8 or 1.85 are common. Note 2: What is the seat size? Ask questions and give info. I didn't so I have 4 sets of springs now............
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 12-10-2018 at 11:24 PM. |
