Liked 7 Times in 6 Posts
Who runs 1 battery and who runs two? I'm not having any issues per se with one, but I am considering adding a second as an insurance policy of sorts. I have 2 gauge ran from the battery (right front corner of the truck bed) to the master switch and 2 gauge from master switch to the front distribution block, then 4 gauge to the starter. It takes it's sweet time to spin over when cold, and if it's a bit low on voltage after spinning over, the injectors stop firing due to Vdrop with the starter spinning.
I talked to a fellow at the OKC Divisional in a dragpak, he said he had to go to 2 batteries for essentially the same reason, fuel injectors and starter simultaneously doesn't add up after a couple starts and nudging forward in the lanes. Once it's warm I don't have any issues. It's just the initial cold start. I keep it on a battery tender, so it's not a low battery issue initially. It just takes 30-45 seconds of spinning before it catches. Worth adding a second battery? |
Liked 431 Times in 224 Posts
I run 2 batteries with an alternator on my door car. I can and have run the entire season without hooking up a battery charger. I also put relatively few demands on the electrical system, with a belt-driven fuel pump and almost no fan usage when the car is not running.
I've not run 16 volts, but I'm considering it for my dragster which has always had 1 battery and alternator. I do put the charger on that after a few runs. I'm not sure if 16 volts is a reasonable consideration with the "daily driver" thing. It sounds like voltage is your primary concern rather than reserve capacity. I understand that more reserve should lessen or slow the voltage drop when demand is high.
S/ST 51 S/C 53 |
Liked 26 Times in 12 Posts
I just changed from the 2 gauge I had on the car for almost 30 years to 1/0 gauge this past week and it was night and day difference in starting this past weekend in Bowling Green.
Liked 704 Times in 281 Posts
Liked 3,179 Times in 972 Posts
All it will take is hot-lapping in final rounds, minimum charging time and getting shut-off just before staging and then an “apparent” good battery failing and you will have another battery in no time. Haven’t thought about going heavier than 2 guage...sounds like good insurance.
#6 | |
The PCM on my platform controls the 3 wire alternator, so charging once running at temperature isn't an issue. Just the initial start when the engine is cold. I thought about using 1/0 wire when i wired the truck, but I thought 2 gauge would be "good enough". It sure beats the 6 gauge it came from the factory with, despite being about 25 feet longer, with the battery being relocated and master switch installed. |
Liked 4 Times in 3 Posts
2 guage has an amperage capacity of about 150 amps at 10 feet with a voltage drop of 2 percent. a typical gear reduction starter will draw 150 amps 250 to 300 for a direct drive unit. remember this is for a fully charged battery. as the battery discharges amperage goes up.
Liked 759 Times in 379 Posts
You don't need 16v but without question you should change out the cable to 1/0. If it's still hard to start, the next culprit is your starter. Whose starter and model are you currently using?
That said, I run two 12v batteries in my dragster and my door and always have because they were built for 2 batteries. ![]() ![]() |
Liked 72 Times in 15 Posts
Battery cables should also be changed out every 5-10 years also. It is getting hard to find good wire and it will go bad. You should also check the terminals on the cables too make sure they are tight. I would suggest doing a voltage drop test on your starter/battery circuits a couple of times a year. It should also be the first thing you do when you are having a starting issue.
Liked 333 Times in 180 Posts
If you use 2 12 volt batteries you can wire the car so that the starter gets hit with 24 volts and the rest of the electrical system is ONLY 12 volts------Ever listen to Greg Andersons Pro car when he hits the starter ??? Cranks probably at 500 RPM(LOL)- It starts RIGHT NOW !!!!Most pick up truck diesels use 24 Volts to start while the rest of the electrical system remains 12 volts ---- You don't need the weight of 2 big 16 volt batteries or even 2 "large" 12 volt batteries to accomplish this if you do it this way---FED 387
