Old 05-16-2018, 08:53 PM   #1
Blair MacDonald
Default 1988 Super Stock Camaro New Price
The following is all the information on my car:
Turn Key 1988 Camaro Super Stock GT, Current GT/JA, NHRA RECORD HOLDER, Chrome Moly Cage, Chassis is Certified for 2 more years, Armstrong 350 cu. 255/294 HP engine, 441 Hettler Heads & Intake, Dart Block, Callies Crank, Manley Rods, small journal and .875 pin, Diamond Pistons, Comp Cam, Jesel Rockers & Timing Belt, (MSD Trigger, Distributor, 7 AL Box & Timing Retard), VDO Play back Tachometer, 3 step coated Headers, True Choice/Koni Front Stuts Double adjustable, Founder upper strut adjustable mounts, QA1 Double adjustable rear coil overs, S & W 4 Link & wish bone, Ed Quay frame cradle, Front & Mid motor plates, Chettah RPM over Air Shifter, Biondo Box, ATI Hardened parts 350 Transmission, TCI Reverse pattern, Transmission Brake valve body, ATI 6100 RPM Convertor, 9 inch Ford rear end with light spool and 583 gears, Moser Gun Drilled and lightened flanged axles, Strange and Willwood 4 Wheel disc brakes, Chrome Moly driveshaft.
Spare Parts: Ashley Quadra Jet Carburetor, 350 ATI Transmission and 6200 Stall Converter, 9 inch center w 5.83, set of Weld Wheels with new Phonex Slicks, Shift Controller, and Fuel pump
Serious inquiries only. 506-536-3611 ask for Blair. New price for the works is $24500
Last edited by Blair MacDonald; 11-24-2018 at 02:46 AM. Reason: NOT FOR SALE ANY LONGER>YOUR LOSS
Blair MacDonald is offline   Reply With Quote
Old 11-24-2018, 02:42 AM   #2
Blair MacDonald
Default Re: 1988 Super Stock Camaro New Price
Car no longer for sale.
