Old 04-19-2018, 08:25 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default unequal four link for super stocker
Some years ago 3rd gen Camaros and Firebirds were built with short upper four-link bars. Ed Quay and others offered frame rails and other hardware to product those builds.
Question; is there any downside to the short upper bar? Does that design react/operate the same as an equal length four link?
If would be for a small block powered package with an ET range of 9.50's
Larry Woodfin 471W
Old 04-19-2018, 09:49 PM   #2
Default Re: unequal four link for super stocker
They tend to be on the violent side when used with a manual transmission or a transbrake, and a bit less friendly to tune. Footbrake cars that don't have a ton of torque or a lot of gear seem to work well.
Old 04-20-2018, 11:56 AM   #3
Jeff Stout
Liked 706 Times in 283 Posts
Ed Quay built my Monte back in 85 with short upper bars. After a lot of playing with it then having a chance to play with equal 4 link bar car I found that any changes to short upper bar seemed like drastic large swings even though you moved 1 hole or changed ride height. The equal bar car when making the same changed seemed more tune able. The Monte worked well but maybe I didn't have enough knowledge back then to figure out little changes.
Old 04-20-2018, 12:28 PM   #4
Jeff Niceswanger
Liked 1,037 Times in 369 Posts
We eventually had Kronenbitter cut out our short bar and converted it to long bar. Like the other guys said, short bars are touchy. For a bracket car that never changes anything,they would be dandy. Really no problem hooking them. But changes in ride height along with changes in tire diameter, makes a perfect acting car act stupid. You cant throw 150 lbs ( sometimes more), in and out of them, and not have issues....
Jeff Niceswanger 3740 SS
Old 04-22-2018, 05:36 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Larry,
The bars on my car are:
Top - 20" C-C
Bottom 22: C-C
The 4 link bracket on the rear end has an 8 deg forward tilt
off of vertical for the top mount.
You will probably have better luck with that than just a vertical on center
rear end bracket. My car liked it even though it shortened the top bar.
Call me if you want the mount distance off the C/L of the housing
and bar angles.
Adger Smith (Former SS)
Old 04-23-2018, 11:16 PM   #6
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
Larry,
Trying to figure out how to adjust our suspension, we found this spreadsheet on the Internet which helped us understand why our car was reacting as it did. It answered a lot of our questions and allowed us to get our car to work pretty good. This same information is available in some of the chassis setup books available.
http://www.patooyee.com/calculators/4BarLinkV3.0c.xls
Larry Merk
Larry Merk is offline   Reply With Quote
Old 04-24-2018, 08:01 AM   #7
Dragsinger
I appreciate everyone's feedback.
The reason for my question, I am looking at a 3rd gen Camaro that is fitted with the Ed Quay style link. That design is from the days when NHRA rules did not allow the floor to be cut for suspension install.
The upper bar is considerably shorter than the lower bar per the Quay design.
My research shows the Quay design is in service with successful racers.
Given this updated information, do y'all have any additional feedback?
Is the Quay design acceptable for a small block powered package running in the 9.30 ET range?
A trans brake launch with engine of about 650 - 670 horse?
Larry Woodfin 471W
Old 04-24-2018, 10:01 AM   #8
Aaron Allison
Liked 150 Times in 43 Posts
My SS/BM Cavalier has a short top bar style four link and we have never had any issues with it and it is very tune-able. We have run the car with a 500 HP GT motor all the way up to the 865 HP modified motor that we have in it today. I know a number of years ago a lot of guys were changing them out, but I think it was a little bit monkey see monkey do.
I know there are a ton of cars out there like mine. I wouldn't be scare of that set-up one bit. If building a car from scratch I'm not sure I would do it, but definitely not worth changing.
Aaron Allison 395 STK, 395 SS, 3395 SC
Aaron Allison is offline   Reply With Quote
Old 04-24-2018, 01:28 PM   #9
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Ed Quay told me Via Facebook just recently why he favored those short top bars and it made sense.
He felt equal length bars could get into a bind easier.
His dragsters used the same shorter top bar style 4 link.
My good friend has one and I know of others and they work well.
I had a short wheelbase Vega and it was originally a 3 link
It had extreme body roll using a trans brake and I cut it out and installed an Art Morrison 4 link with short top bars due to limited space.
Car worked fine and I ran as quick as 9.30 footbraking.....and used a trans brake for S/G .....
The next owner ran some 8.80's with it and added an anti roll bar and a strut front end to replace the a-arms that it was built with.....
Rich Biebel
S/C 1479
Stock 147R
Old 04-24-2018, 03:11 PM   #10
CMcAllister
Liked 920 Times in 259 Posts
With hole spacing being the same on the chassis bracket, the shorter bar will be a much more drastic change when moving the front up or down a hole. It can go from too much angle to not enough, (too much change in IC location), with no way to split the difference other than a ride height change.
Also, the IC change throughout the normal rear housing movement will be much greater, depending on how much the rear moves. Even if you've found the sweet spot, this can still cause problems.
IMO, the short bars were a compromise for the situation at the time. The trend now is to make the adjustments finer, with smaller holes in brackets, tighter center-to centers, multi piece brackets allowing for 1/8" changes in location, and/or longer bars making this so.
CMcAllister is online now   Reply With Quote
