Liked 184 Times in 113 Posts
Live in Montgomery County, MD - Rockville/Germantown
Need a NHRA Certified Roll Bar Installed ! Who and where can I get this done? Dan |
Liked 311 Times in 175 Posts
You want one of the best? Ken Keir Race Cars.
Liked 431 Times in 224 Posts
Is there such thing as a NHRA certified roll bar?
S/ST 51 S/C 53 |
Liked 319 Times in 68 Posts
Dan, I've used pre made kits from S&W and had good luck. Make sure the bar is installed as per the rule book.
Lee Valentine 1661 STK |
Most kits on the market are .134" tubing to make sure it meets the min. of .118". A quality shop will use .120" or .125" and check the thickness to make sure it will pass. They may have to buy DOM tube, more money, better product.
#8 | |
Liked 372 Times in 130 Posts
Both of my Stockers have S&W kits. Very pleased with their quality and customer service. One thing I did find out after installing the kit in my 2009 Stocker : If I had special ordered a "relaxed fit" main hoop cross bar with a 2-3 inch set back ( instead of the normal straight piece) then my seats could have reclined further back. I did not know this until after I installed the kit. Being a novice at roll bar installations, I can now see why chassis shops charge so much. To fit things right it takes a lot of time
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#9 | |
Would like a Roll Bar setup where you can get out of the Seat easily without being Gumby ! Also be able to sit in the back seat. Thanks Dan Last edited by Dan Fahey; 03-13-2018 at 02:31 PM. |
#10 | |
here are the pics of the 09 Mustang. Because the seat back did not lean back to it's normal position, I had to "flip" the head rests...otherwise with a helmet on there's no way I'd be comfortable. I may still cut the cross bar out and install a 2" setback version Also, I think it may be tough to make it easy to sit in the back seat by following the current rules regarding roll bars. I tried to crawl under mine. Going over would be easier if I needed to. I do like the fact that I can remove any of my seats easily ![]() ![]() ![]() ![]()
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT Last edited by ALMACK; 03-14-2018 at 11:58 AM. |
