#11 | |
Liked 237 Times in 126 Posts
AFR `1399 58cc valves 1.9/1.6 I runner 165cc E runner 68cc c8oe f J code 302/230 49.5cc valves 1.783/1.457 I runner 130cc E runner 49cc Got iron heads now.
#12 |
Liked 128 Times in 50 Posts
Any modifications to the runners are illegal, so if they match up to the stock numbers NHRA will know they are modified.
Bobby Lundholm 3516 G/SA |
#13 |
Liked 71 Times in 38 Posts
So if I’m understanding this correctly , you must run the aluminum/ replacement heads in either stock or super stock using the runners as they come from the manufacturer. The exception being replacing the valves and seats with the correct OEM sizes?
#14 |
That's what I'm understanding. The air flow is going to be restricted by the intake regardless, so with the larger head runners i don't think it'll help that much.
#15 |
That's what I was told regarding my AFRs. Smaller valves would degrade the heads performance. The shop that does work for Hancock and Lane advised against that route.
#16 |
Banned
Liked 235 Times in 110 Posts
I know of at least one stocker 428 CJ intake manifold that is 10 lbs lighter in wt. than any others. No grinding on the outside either !
#17 |
Anyone notice that the approved Dart head is iron?
Dart catalogue Iron EAGLE s/s 23° 165cc (55-86 Std. Intake Face)
72cc Chambers – 1.940”/1.500” Valves 10021070 Bare Head NHRA Accepted Stock/Super Stock Cylinder Head Volumes Updated June 14, 2017 Highlighted items designate recently added since last revision Head # 10021070 Dart Intake CC's Max 172 Exhaust CC's Max 65 Same As Stock 80-92 305; Same chamber CC's, valve sizes as head replacing intake and exhaust
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 02-22-2018 at 01:13 PM. |
#18 |
Yes that one is on the top of our list to work with.
#19 |
I still don't think you make the intakes big enough to really let the heads breathe. What's the standard CC of the stock Chevy intakes compared to a 185 cc head runner?
#20 |
Liked 50 Times in 23 Posts
#1 Greg Hill; The Edlebrock heads are 185 cc’s on the intake runner. Who approves this stuff?
Follow the money............ # 2 Todd Hoven "Great thing about aluminum. You can weld it up, reprofile it, and cover it up. It will look like new and you probably pick up 30 hp at least. " Think about it, Read between the lines.. this also applies to Aluminum Intakes... # 3 "I was looking at them and the Dart look to be the best without going to the aluminum heads" Don't count on it , if this deal stays at +5hp for replacement heads, the Iron will be way disadvantaged, esp if the combo has an Alum Intake. refer to comment #2 Obviously, no one who has a clue of stock eliminator made the decision to include these alum heads replacing factory cast iron. I'm not a chevy guy but now as I see it in the guide the 350 has choices of 4 replacement heads plus the original. As mentioned in another thread here on CR that potentially creates 5 sub combos of the same engine. In the future will we need 5 hp factors for the same engine? Yea, and this goes for all the Makes also, whether it's a Mopar Ford or GM.
Steve Stickel 1161 Stk 1167 SS |
