Old 02-15-2018, 11:24 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Question on Caltracs
I am about to order my Caltrac split springs springs for my 67 Cuda that will be running in K/SA. On Calvert they give me an option from a 1+ height, neutral -1 and -02 heights.
Which one would be the best choice?
Old 02-16-2018, 02:56 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Question on Caltracs
That body style is similar to my 68 Mustang coupe. I had the lowered springs and had tire clearance issues. Replaced them with the lifted versions - +2. I think - and I run 28/10s in there with mini tubs. Might be able to fit 30/10.
Dale Shearon
68 Mustang 6394
Old 02-16-2018, 04:21 AM   #3
David Lee
thanks, i have a set of the older SS springs on it now. and a old set of MT 29" slicks. I will see how it looks and fits and make my determination then.
Old 02-16-2018, 05:34 AM   #4
GTX JOHN
Liked 2,516 Times in 701 Posts
Our A body stockers are at neutral.
John used to make a narrower spring that made tire clearance easier
to work with on A Bodies. Duster and Demon really do not need them but
they make it much easier on earlier A body cars and some of other A body stuff like 67 to 72 Darts.
John Irving
741 Stock
741 Super Stock
Old 02-16-2018, 05:43 AM   #5
David Lee
Thanks John, one day owe you a big dinner
Old 02-17-2018, 08:17 AM   #6
Liked 10,966 Times in 2,260 Posts
After you get the springs and you want to adjust ride height, it is easier to adjust up than down.
Old 02-17-2018, 10:05 AM   #7
Dave Gantz
Liked 251 Times in 125 Posts
With respect to the commenters (and lots of other racers who run his stuff), I would call Calvert.
Old 02-19-2018, 11:14 AM   #8
1arunem
Liked 6 Times in 3 Posts
Also keep in mind whatever you get, when you first install, they will settle and change. At least mine did. I got stock height and was worried it was too high at first but they settled in nicely.
1arunem is offline   Reply With Quote
